Old 08-10-2004, 10:57 PM   #1
another cracked head???
My Ride: 87 Daytona Pacifica
Hello. I have my 87 daytona pacifica 5spd 2.2 turbo I giving me problems again. Had a new head and gasket put on in May because the old head was cracked. It ran great after the work, pulling 10 pounds of boost. Now it is down to 8 psi of boost and it is starting to loose a little bit of coolent every now and then...is my cooling system shot therefore ruining these heads? Should I expect a free repair because they didn't fix it right the first time?? I know the symptoms now are vague, but i don't know if i should fix it...i have so much money in this car its crazy...
Lee'sdaytona is offline
Old 08-11-2004, 11:58 PM   #2
Join the club, arggggggg
Does it run hot, overheat????? losing 2 psi could be wastegate, hose came off etc. As for loosing coolant, how much exactly? Have you pressure tested the cooling system, its possible your waterpump could be leaking, rad leaking etc.
Old 08-12-2004, 12:01 AM   #3
...hey thanks for all your help...lol you helped me with my air fuel gague...lol...i have so many issues with this car...the turbo is only a year old...so i don't think thats the prob...maybe the pump is leaking a little...but i don't see any drips on the driveway...the hoses are new...have not pressure tested the system yet....just hope the coolent isn't getting into the oil again...lol
Old 08-12-2004, 12:03 AM   #4
...oh yeah...it doesn't overheat...i top off the coolent reserve about once every 2 weeks
Mortgages | Loans | Mortgages | Internet Advertising | Remortgages
Page generated in 0.29298 seconds with 13 queries
