Old 08-23-2004, 04:23 AM   #1
Going to rebuild the shortblock soon enough..
And I've made a list, I hope it doesn't come out too long.
Mopar Performance Head Bolts
Sealed Power Rings
Clevite 77 Main Bearings
Clevite 77 Rod Bearings
Intermediate Shaft Bushings
Mahle 2.5 Pistons
T-2 Rod Bushings
89-up Lower Gasket Set
Cam/Intermediate Shaft Seal
Intake/Exhaust Manifold Gasket
Mopar Oil Pump/pickup
MP 2006 Head Gasket
Plastigage
Timing Belt Tensioner
I figure that should cover the block. Is all of that ok for 13 second 1/4 power level, considering I will intercool it with +40s for fuel, 255 LPH Walbro, and an AFPR?
I would get an EGT guage or a DD a/f meter.
Also, the block on question is a CB with 187k miles on it, the head is off and I am going to buy a turbo because I believe the oil seal went on the one it has and I'm gonna try to get it to run before I yank it and rebuild, there is some crosshatch on the 2 cylinders I was able to see. What do you all think is a good assumption on how much block work I will need, also if I need any crank work how much can that go up to? Thanks again!
SK
89ShadowESTurbo is offline
Old 08-23-2004, 08:25 PM   #2
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
Take it to your nearest reputable engine rebuilders and show them the stuff. We can't tell you over the internet since the stuff needs to be measure accurately. Most likely at least a fresh hone and a hot tank.
If everything is bad:
Bore and hone
Crank grind
re-size rods
deck block
align hone the block
hot tank
LancerShelby is offline
Debt Consolidation | Jokes | Personal Loans | Mortgages | Shares
Page generated in 0.40717 seconds with 13 queries
