Old 10-03-2004, 10:35 PM   #1
piston to wall specs
well got my short block ready to go back to the engine shop and got to look at a few things up close,first the main front crank seal is leaking oil, and i noticed that i can move the JE forged aluminum with file fitted moly rings a little back and forth.is this normal? i have heard that the forged pistons need a little more clearance than cast.it isn,t any huge play just a small side to side.compression is really good ,a little high maybe,at 145psi with # 1 being 140.so just wondering if the pistons are supposed to be like that or they are to lose.???
shadowdude is offline
Old 10-04-2004, 01:36 PM   #2
My Ride: 87 Shelby CSX
J.E. recomends .0035" total clearance for thier .020" (3.465") over Forged pistons. That is .00175" clearance for each side of the piston. Yes, they do move a little. You also must take into consideration that some of that movement is diagonal movement and may seem to be alot of movement wall to wall.
Stratman is offline
Old 10-04-2004, 09:50 PM   #3
145psi sounds right on!
mo' parts is offline
Loans | eBay | Per Insurance | Currency Converter | Loans
Page generated in 0.31645 seconds with 13 queries
