12-01-2004, 10:19 PM
#17
My Ride: '87 Omni
Engine: Dodge 2.2
The only eagle rod i've ever seen in person were broken. They came out of an n/a drag car and it had about a 90* counterclockwise twist in the center then it separated, the guy was lucky though the piece left didn't touch anything inside the engine. It didn't look like an rpm failure, it looked more like an excessive power failure.
I've never heard anything bad about them though, but this guy said he had gone through 3 total in a few years with them....
12-02-2004, 10:52 AM
#20
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
If i was gonnna go thru all that trouble to get the crank to accept Chevy rods, I wouldn't use Eagles. Don't get me wrong, they are a good rod for something up to say 100hp per cyl give or take, but not much more than that.
12-02-2004, 11:23 AM
#22
My Ride: 88 Plymouth Reliant
Engine: 2.5L T2
does anyone actually have some concrete evidence of eagles breaking at a certain HP level????????
Brian
12-02-2004, 11:29 AM
#23
My Ride: 93 Dodge Shadow R/T
Engine: 2.2 DOHC Lotus
Brian
My cousin lost an engine in his Sunfire with a Turbocharged Ecotec because of the Eagle rods.
12-02-2004, 01:35 PM
#26
Engine: 2.5L T2
still no concrete evidence..........
Brian
12-02-2004, 05:17 PM
#27
My Ride: 84 rampage
Engine: 2.2L T3
Originally Posted by Shadow16V
Do you happen to recall the Stock Wrist pin diameter on the SRT-4 Rods. If I recall correctly the stock size on the NA 2.4 is 0.866" It's been awhile since I looked all this up and I may be wrong.
They share the same wrist pin diameter as our 2.2/2.5 motors.
Originally Posted by DodgeZ
Like I said in my previous post, the Mistu guys have good luck with them, but the eagle rods for our motors use smaller rod bolts, which i believe would compromise strength. The guys at Forward Motion agreed with me that the t2 rod was still a better choice.
BTW, I am friends with the guys from DSMotorsport, and they know the Horizon
12-05-2004, 12:36 PM
#28
My Ride: 99 Cummins
Engine: 5.9
12-05-2004, 12:42 PM
#29
Originally Posted by Timmay2
If I were speaking to a sales person I may have expected that. I was however speaking to someone in there tech dept. I have deal with this guy before when I had a set of rods let loose in a Ford 347 Stroker I had built. No, it didn't have eagle rods originally, but it does now. I originally used a SCAT Crank and rods. The car lasted about 4 days, small end of the rod broke and Destroyed the Piston, head and block. I transfered the crank to a new block and then installed Eagle Rods and a replacment piston. Eagle was Very helpfull to make sure I got a set of rods that would hold up, yet they advised me to use the Stock rods in my TIII.
12-05-2004, 01:04 PM
#30
My Ride: 99 Cummins
Engine: 5.9
Just messin with ya.. little bored this morning. And btw, the tech guy just didnt want you calling back!  ..
I do agree though, stock parts have been plenty proven.
