10-20-2004, 07:58 PM
#23
My Ride: 1987 shelby csx
Engine: 2.4 dohc conversion
Originally Posted by Chris Faulk
How'd you get a handle on it Kevin?
went to a g-head ha ha,no i use the felpro 9296pt and torque to 92 ftlbs then back all off this seems to seat the o-ring then retorque to 87ftlbs.this is with arp studs, when i originally bought studs had problem with head lifting i talked to a guy at arp told me the studs need to be pre stretched,you know how they make the snapping sound when torqueing they are not supposed to do that when pre stretched.i was told to torque and loosen 5 times and they were right on the money no more snapping.i think when not running an o-ring the mopar hg is the best, but with the o-ring wasnt seating well for me,i think the fire ring on the mopar hg is a little harder than the felpro which could explain it not sure.i would not run a felpro hg on a non o-ringed block.with this setup i have ran 26psi with 29 degrees total advance.and 35 total to 21 psi with 110 octane.
