Old 10-16-2004, 08:07 AM   #1
Question Outside of #1 and #5 main bearings wear faster?
This engine has roughly 50K miles on it,when I tore my engine down I noticed that the OUTSIDES of main bearings 1 and 5 had more wear than the rest of the bearing..and alot less wear than the mains #'s 2,3,4. There was copper showing through. Is this normal.or is this WRONG?
The oil light was coming on at hot idle as well as the guage falling off..but the oil pressure sending unit was leaking too.
1989 LeBaron Coupe|2.5L Turbo I Auto
Under Restoration..and then some!
http://www.cardomain.com/memberpage/420349/1
The Barron is offline
Old 10-18-2004, 09:39 AM   #2
ANYONE?????
I have to correct myself.. I mean MORE wear.
Old 10-18-2004, 09:49 AM   #3
They probably don't get as much oil as the others, and running it with low oil pressure caused them to wear.
lametec is offline
Old 10-18-2004, 07:48 PM   #4
was plasitgage usewd on the build?
could be bowed/bent crank, seen it happen alot.Guys will lie there cranks on the side for weeks and months at time causing warpage.Even leaning the against a wall can screw them too.
deadtd is offline
Old 10-21-2004, 07:53 PM   #5
Have your block and crank checked for straightness, something is amiss. Also, could be badly out of balance, that will chew up bearings. I just recently got a used engine with 150,000 kms and the bearings were still good, no copper or abnormal wear marks, ditto for my old engine.
Old 10-25-2004, 07:38 PM   #6
wickedshelby
as far as oil starvation, see if the oil gallieys in the crank are plugged or constricted
Old 10-26-2004, 12:16 PM   #7
That won't cause his problem hes having!
Old 10-26-2004, 12:40 PM   #8
I'm having the same problem on a freshly rebuilt motor (50 miles and counting). I'm interested in finding out why ... (now subscribing to this topic )
ForceFed Wraith is offline
Loans | Loans | Mortgages | Ringtones | Manga
Page generated in 0.38965 seconds with 13 queries
