10-23-2004, 02:12 PM
Originally Posted by lametec
No, .025mm is correct. It's for engines that have a little wear (high milage, but still on good shape), and you just want to freshen up the bearings. Crank is not machined in this case.
.25mm is the first "rebuilt" undersize.
In other words, .025mm is correct, and is 1/10th the oversize of .25mm. You'll need to find some .25mm undersize bearings.
Ok .. thanks for the clear up.
I ordered a set from another place .. (.25mm) and went to pick them up today. However, when I went in, they had .5mm bearings delivered to them! ARGH! .. How can this happen TWICE? I mean, I state the size I need like 3 times before I leave the store. Anyway .. sorry about the rant. Tuesday is the day I get the proper sized bearings (hopefully) and finish up the car. Thanks for the reply.
The bearings will be Federal Mogul ....
