Old 10-22-2004, 11:08 PM   #1
T-II crank casting number
My Ride: 87 GLHS #508
Engine: 2.5 T-II
What is the casting number(s) on a T-II crank? Looking up parts online, some applications are by casting number. Appreciate if anyone having a T-II carnk around could LMK. Thanks.
denviola is offline
Old 10-23-2004, 02:20 AM   #2
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
Just so you know, there were two different TII cranks. One for '87-88, and one for '89 and up TII TIII and TIV common blocks.
Cast cranks have proven reliable in applications of 400+ hp.
contraption22 is offline
Old 10-23-2004, 07:08 AM   #3
Engine: 2.5 T-II
After reading info on this site, maybe the post should be changed to "can you use T-II rods with a cast crank?" or "Am I ok if I add an intercooler and MP computer to a T-I without beefing up the lower end?" I've now seen a lot of posts about cast cranks being ok for lower HP apps, and lots of different discussion on the rods. The extra metal on the big end of rods seems to have an equal number of persons that think it is great and those who say it is no big deal and the stock rods are fine.
Appreciate the opinion, anyone else?
Denny
denviola is offline
Old 10-24-2004, 12:28 AM   #4
My Ride: 88,89,90 Shelby's
Engine: T2's and a VNT
People are using the cast crank in high hp engines, so I'd say it was fine to use. The rods.. depends on the year. You should be ok as long as they are not LW's. (86-88t1?)
and yes you can use T2 rods with a cast Crank (89-up). Stock 89-up 2.5L T1 common blocks use that setup.
What are you plans anyways? There are a lot of variables If its not common block parts.
Turbo Charger is offline
Old 10-24-2004, 02:23 PM   #5
fwdmopar15401
Mopars casting number for the T-II Forged Steel Cramkshaft is "4323815" thats the 87 to 90 2.2
Old 10-24-2004, 07:02 PM   #6
Engine: 2.2 Turbo
That must be a missprint, because common blocks (89-up) and pre-common (88-earlier) cranks are not interchangable.
Old 10-24-2004, 08:38 PM   #7
fwdmopar15401
The diffrence between the 2 blocks are 11mm in deck height....... if you are using a 2.2/2.5 "CB" thats the Crank Forging number to use.....but it will fit into a non "CB" the 2.2 crank in a Long 2.5 block will de-stroke the motor, lower the compression down and the piston will sit 6.125mm lower then the top of the deck. The cranks throw for the 2.2/2.5 "Common Block" is 92mm
and the old style 2.5 is 104mm
Just remember the real thing to watch for and its not that big of a problem is the older cranks used 6 bolts for the flywheel (1981 to 1985)and the newer cranks (1986 to 1994) use 8 bolts. The fix here is just get the flyweel need for the crank
Other Cranks that are Forged Steel are STROKER Cranks From Mopar Performance
PT#
P4592109 (3.62" stroke)
P4529444 (3.246" stroke)
P4529445 (3.994" stroke)
High Performance Cast Cranks PT#
P4452744 (2.2L 8 Bolt)
P4349931 (2.5L 8 Bolt)
Buy PSP | Advertising | Personal Loans | Lingerie | Personal Finance
Page generated in 0.37948 seconds with 13 queries
