Old 10-24-2004, 02:03 AM   #1
88 rods on 85 piston pins?
daytonashelby88
Ok, so I finished pulling the head on the 85 Daytona Turbo and found cracks in 2 pistons. I do have used 88 Daytona Shelby Z pistons and was wondering if I could use 88 pistons/floating pins on 85 rods? Thanks in advance.
Old 10-24-2004, 02:19 PM   #2
fwdmopar15401
if they are turbo pistons and are floaters as well then they should work
Old 10-24-2004, 02:39 PM   #3
My Ride: 1985 Shelby Charger
Engine: 2.2 T2
You will need to have the rods machined/honed for the full floating pin.
crazy1eye is offline
Old 10-24-2004, 08:17 PM   #4
You can use the 88 pistons on the 85 rods without any problem. As the 85 rods are press fit you will have to have a machine shop do the swap as the press fit rods need to be properly heated to have the wrist pins installed. The wrist pin "floats" in all pistons, it's the rods that are either press fit or floating.
The 88 pistons have a larger dish than the 85 pistons so your compression ratio will be slightly lower, great for running higher boost. Off boost throttle response will be a little more sluggish with the lower compresssion however.
Thanks
Randy
Glhs60 is offline
Old 10-26-2004, 10:19 PM   #5
Or you could just have the pins pressed into your 85 rods and not have the floating pin effect in the rods, as they were originally in your 85 engine. A good machine shop will be able to do this for you.
I used to by 88 pistons for my 86 non floating rod engine in bulk and have them pressed in.
Joey
gaboon is offline
Old 10-28-2004, 06:23 AM   #6
als
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
just use the whole thing why change the rod, just have rods resized and use new rod bearings, while your in there install new oil pump to. can,t hurt,good luck. als
als is offline
Old 10-28-2004, 08:15 PM   #7
My Ride: 84 Chrysler Laser XE
Engine: 2.2 Turbo II
because 85 rods are the HD type(like a TII rod but without the HD rod cap), and an 88 will have the LW rods. You could use the caps off your 88 rods on your 85 rods and have what is more or less a TII rod, you would just need to get them resized on the big end.
topdollar69 is offline
Credit Card | Loans | Loan | Car Loans | Xbox Mod Chip
Page generated in 0.33666 seconds with 13 queries
