Hello all...
well....
I am of course having a change of plans about midstream here...
I am going to put a stone stock good running 2.2L TII engine in my omnilet and run a TU hybrid To4E50/stage III-.63 housing/ TU 3 inch swingvalve with the TU turbo header on it also....
Full 3 inch exhuast..
255lph HI po pump intank, TU cal with 3 bar map,cometic head gasket, head studs, stock pistons, etc... ported swirlie head with TII 2 piece intake and stock throttle body , +40 injectors, relentless fuel rail or modified stock rail, not sure yet....
2.5 inch intercooler plumbing, all mandrel bends, welded and powdercoated
dual saab core intercooler with both inlet and outlet on driver's side...
No ac....
What is the max horsepower possible while keeping the stock pistons alive in this engine??? I am also running a rebuilt, mildly tricked out a413...alto red clutches and koleen steels and a high pressure shift kit and adjusted governor system...
I have never had a 2.2L before in the car, always been 2.5L... I have heard that the 2.2L would hold much more power on the stock mahle pistons than the 2.5L mahles would hold....
With my combination of parts, it should be capable of around 320-350whp pushing it hard... around 22-26psi boost....
I have a wideband that I will monitor things with and keep it fat and happy....
what do you guys think??? will the little 2.2L turbo II hold the HP???
I think I am gonna risk it....
I am going to put my nasty shortblock together with a neon head and put it in a stripped out 1985 GLH that no one would buy from me...
I am going to try and get it to <2000lbs if I can....
I have a fully built shortblock with GRP rods, coated venoilas, coated bearings, fully balanced, dry sump oiling, total seal rings.... on and on... and I am going to be looking for 550-600whp out of it... Gonna run a VEMS computer on it also!!! TWO WIDEBAND o2's .....
I'm Rick James, BIOTCH!!!!
RYNO
OMNILET
part deux
