Old 10-29-2004, 11:53 AM   #1
Best way to clean motor of oilant?
After blowing my headgasket last weekend, my 2.5L is filled with oilant in both the rad and the oil pan. Whats the best way to make sure everything gets cleaned out when I drain and refill the fluids after the gasket change? Would a simple backflush of the cooling system and an motor flush with a new oil filter along with an oil+filter change be enough?
skierd is offline
Old 10-29-2004, 12:05 PM   #2
Motor flush not needed. Keep the old filter on, drain the old oil, add 3 litres oil, 1 litre trans oil and run it till very hot, drain, change filter and refill with oil.
For you coolant, add some coolant flush stuff, run, then flush.
Old 10-29-2004, 07:51 PM   #3
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
I wouldn't worry about the rad fluid in the oil, it'll burn off once it's up to temp. Just change the oil that's in the pan and you'll be fine.
LancerShelby is offline
Old 10-29-2004, 07:57 PM   #4
Water will burn off, coolant won't. Flush it out, it destroys bearings!!!!!
Old 10-29-2004, 08:48 PM   #5
My Ride: '87 Omni
Engine: Dodge 2.2
Coolant goes straight to the pickup, displaces oil, when you change the oil, it'll be the first out, not a bad idea to change it twice though.
Putter is offline
Old 10-29-2004, 09:21 PM   #6
Not if the engine has been ran, will be chocolate milk!
Old 10-29-2004, 09:25 PM   #7
My Ride: '87 Omni
Engine: Dodge 2.2
I used to drink chocolate milk, but it didn't taste anything like the milk that comes out of these motors (maybe the nipples went bad?).
Putter is offline
Old 10-30-2004, 09:03 PM   #8
You've tasted it , your a sick man, lol!
Old 10-31-2004, 03:39 AM   #9
My Ride: '87 Omni
Engine: Dodge 2.2
no i havn't tasted it.....but we were out drinking one night building a trans for a geo..and one of the guys that was here got the bright idea to pull the dipstick out of my go cart and lick the oil off of it. It was straight 30 that has 2 seasons on it on a 8hp techumsa....talk about gross pretty funny though
Putter is offline
Mobile Phones | Mobile Phones | Loans | Web Games | Proxy
Page generated in 0.34139 seconds with 13 queries
