Old 11-01-2004, 09:58 AM   #1
Needed-engine Specs!!!!
Hello all....
I need to know the bore size of the new 2.4L turbo engine in inches...
Also, I need to know the stroke length in inches or mm...
Also, what is the rod length in inches???
What are the specs on a 2.5L engine? for these same part dimensions?
Thanks!!!
thinking about doing sumpin'
RYNO
OMNILET
Part deux
Turbofreak is offline
Old 11-01-2004, 11:25 PM   #2
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
Why don't you do sumpin' like buy some manuals.....
LancerShelby is offline
Old 11-02-2004, 01:05 AM   #3
info
Bore -- 3.44 (87.5)
Stroke -- 3.98 (101)
Bore-to-stroke ratio -- 0.87
Block length -- 16.43 (417.3)
Block height -- 9.36 (237.8)
Rod length -- 5.94 (151)
Connecting rod L/R -- 2.99
This is for the n/a engine but it is the same for the turbo form what I have heard.
Since the 2.5 common block is the same as the 2.2 then it has
Bore 3.44in 87.5mm
Stroke 4.09in 104.0mm
Deck height 237.8mm
Center to center distance for rods is 151.0mm
For info regarding the 2.4 turbo http://www.hotrod.com/techarticles/e...rt/index1.html
For some more info on the 2.4 turbo
http://www.allpar.com/mopar/24.html
I hope this helps you out.
Daniel Merrill
89acclaim is offline
Old 11-02-2004, 04:18 PM   #4
The stroke is different on a 2.2 vs 2.5L!!! Will look it up later!
Old 11-02-2004, 04:38 PM   #5
Originally Posted by 89acclaim
Bore -- 3.44 (87.5)
Bore 3.44in 87.5mm
Deck height 237.8mm
Daniel Merrill
YES!!!... I had forgot where to get the specs from and was wondering... looks like the only difference then is the stroke is .110 longer on the 2.5L versus the 2.4L....
4.09 vs. 3.98 = .110
151.oo mm rod is 5.94 inches long.... so that is the same and the bore sizes are the same...
I wonder, what is the deck height of the 2.4L engines pistons? (how low do they sit in the bore below the edge when at TDC? )
Most factory pistons are .050 below the deck usually anways, so I am wondering if I couldn't just destroke the crank about .040 off the stroke side, and then use 1mm undersize bearings.... I dunno....
THANKS!!!
RYNO
OMNILET
Old 11-02-2004, 04:39 PM   #6
I hope that was meant to be funny...
RYNO
Old 11-02-2004, 06:11 PM   #7
Engine: 4cyl. 2.5L
RYNO
Ummm, no. You need the manuals anyways, unless you have a photographic memory?
Old 11-02-2004, 07:29 PM   #8
If you are thinking about makeing a hybrid then 2.4 with 2.5 rods and pistons then check out http://home.bellsouth.net/p/s/commun...upid=45129&ck=
and the 2.4 PT pistons at TDC is short of the deck by .240".
you can find that info at http://www.bstockum.com/
I hope that helped.
Daniel Merrill
Old 11-03-2004, 03:01 PM   #9
I would like to amend that last bit. http://www.bstockum.com/ also lists the pistons being short of the deck at .30" Humm needs to be double-checked.
Daniel Merrill
Repair Bad Credit | Mobile Phones | Cash ISA | Loans | Loans
Page generated in 0.50869 seconds with 13 queries
