11-02-2004, 06:59 PM
My Ride: 85 glh turbo
Engine: 2.2 turbo
1/4: 11.510
Originally Posted by Vigo
is anyone running something close to 9:1 compression in their turbo engines, if so why and what does it get you?
A friend of mine is. It wasn't planned that way. Something was missed, either the cc of the head or not enough dish in the piston. It runs fine but he cannot run the boost as high. I would just stick with 8.0-1.
11-03-2004, 01:46 PM
I ran tbi pistons for 3 days, at 12 psi of intercooled boost before it melted down, badly.
But it had great throttle response, less turbo lag, and the power was more linear. This was with a stock TIII turbo and a 50 trim compressor wheel and matching housing.
11-03-2004, 04:33 PM
im thinking of running 14 psi or so, intercooled, on a 2.5 tbi, with a stock garrett.. seems like with the timing pulled back it shouldnt have any trouble there??
along the same lines, has anyone noticed a big difference in how much boost you can safely run based on water or oil temp?
Theres more than timing involved. Inorder to safely run 14 psi, you will have to pull the timing back alot, enough that it will be gutless without the turbo. Need a big ass intercooler and lots and lots of fuel. Mine got so hot at 12psi even with my airfuel gauge reading perfect that I melted and bent the spark plug electrodes.
11-03-2004, 04:52 PM
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
I'd bet that tossing a G head onto a TBI block would do wonders towards pulling this kind of stunt off. You get a .5 compression ratio drop (so I've been told) and combustion chambers that are less prone to detonation.
Me, I'd run 6:1 compression if I could.. heh, scare the kids with 50psi of boost. ;>
11-03-2004, 06:29 PM
so, seeing as how some t1s with mitsus run 12-14 psi non intercooled and dont melt their pistons in a matter of days, you're saying that a cooler running turbo, an intercooler, less timing, and possibly some colder spark plugs just plain dont make as much difference as 1 point of compression?
ive run my 2.5 tbi as 4 degrees base timing and it ran about the same down low as a stock 2.2 tbi, so i dont think running maybe 8 degrees instead of 15 would hurt me too much.
But thats a tbi, I see what yuor getting at, all I can state is what happened to me, tbi pistons, 12 psi, intercooled, TIII turbo with 50 trim compressor, air fuel gauge showing good, no EGT at the time, timing at 10 deg. I lasted 3 days, melted down 3 sets of plugs then melted #3 piston badly. At the time, couldn't figure out why until I took it apart, and someone had put tbi pistons in a turbo block, dumbass's but it gave me some more learning.
11-03-2004, 07:42 PM
My Ride: '89 Mini
Engine: 2.5 common
I had a 2.5l tbi in for 4 months but had to light pedal it. It would ping above 5psi @ 14 degrees advance. Ran GREAT with race fuel, not a hitch, but finally holed a piston on the street against an STS. I had a swirl port head, though. A buddy had a Rampage with a 2.5l with a G-head and never had any trouble. No intercooler either at 13psi.
11-03-2004, 11:21 PM
#12
not trying to offend or anything, i do appreciate your input.
but it sure sounds worse than i would imagine.. i cant see the tbi pistons being so much worse than the turbo pistons that they'd fall apart under such mundane conditions as 12 psi intercooled. i know a guy thats run a 75 shot of nitrous on a tbi motor for over a year and hasnt had problems, i would think 12 psi intercooled wouldnt even be as harsh as that.
but im not the one whos done it, which is why im asking
heres another question (still want input on the 1st one tho!)..
will turbo pistons/rods bolt right into a tall block 2.5? 87 pistons/rods in this case?
11-04-2004, 07:10 AM
#13
My Ride: 1987 Shelby GLHS 189
Yes, people are running higher compression
11-04-2004, 11:48 AM
#14
No offense taken,
To run higher compression, you need to take in a bunch more variables, thats all I am trying to say. 12 psi 8.7:1 is easier and safer than 12 psi at 9.5:1.
Yes, the pistons and rods work, as I found out. Tall deck? 2.2L's and 2.5L's have the same deck height!
