11-09-2004, 02:23 PM
Cracked Block
My Ride: 96 neon
Engine: 2.0L
My daytona had some issues when I bought it, which I am in the middle of sorting out. Just a quick run-down: the car was smoking, and stalled out on cold starts. Only way to keep it running was to tap the gas. After oil change, there was a strong smell of fuel in the oil. It was later found the the vac lines where off, causing it to run really rich. Once vac lines were corrected, the smoke went from dark black to a greyish color. There was also a sweet smell from exhaust fumes. It was at night. Head is not cracked, as it was removed and pressure tested. Now in this process, it was discovered that the coolant levels were very low. This was why the head was pulled. Is it possible the block is cracked, even though there is no coolant in the oil?
Just trying to get an idea of what is going on. Now to go out in the cold and put my car back together
