11-13-2004, 06:06 PM
Journal dresser ... a hand tool?
My Ride: '89 Daytona Shelby
Anybody ever seen something like this? I'm imagining a "O" shaped ring impregnated with industrial diamond .... attached to a nice hickory handle.
Imagine an oil filter wrench.
I fabricated a homemade tool to dress a rod journal under the car. I used a short length of spring steel banding. I bend the ends and sized it to the journal diameter allowing for a thickness or abrasive paper. The abrasive paper was wrapped over the ends and taped down. Added a little water and dishsoap. The two bent ends got clamped with a large vicegrips around the journal. All I had to do was swing it around.
I mic'ed the shaft before and after and was surprised how well this worked. The steel banding flattened him pretty good. The real proof will come when I check the bearing running in that rod. I let you know how that goes.
A tool like this would be slick for touch ups in or out of the car.
