Old 11-13-2004, 08:36 PM   #1
will 2.2l/2.5l turbo pistons fit in 2.0l neon?
hybridneon20
does anyone know if since the bore is the same on the neon sohc 2.0 and the 2.2l or 2.5l turbo if i can use the turbo pistons in my neon to lower my compression ration for higher boost on my neon? any help would be greatly aprreciated
Old 11-13-2004, 09:01 PM   #2
Bore for the Neon engine is 3.445" or 87.5mm
Bore for the 2.5L is 3.44" or 87.4mm
So yes but you will have to check the wrist pin height between the 2 engines.
Old 11-13-2004, 09:53 PM   #3
turbo pistons
hybridneon20
you dont by anychance have a set of pistons u can check it all for me so i can match up to my stock pistons do you ? it would be greatly aprreciated
Old 11-15-2004, 11:37 AM   #4
I will check today for you!
Old 11-15-2004, 09:03 PM   #5
turbo pistsons
hybridneon20
thanks alot man
Old 11-17-2004, 10:54 AM   #6
My Ride: CSXT
I heard that you can remove 1 of the shims in the neon HG to lower compression by a bit. Not sure if you already know that or not.
juxsa is offline
Old 11-17-2004, 12:33 PM   #7
turbo
hybridneon20
blah
Old 11-17-2004, 12:34 PM   #8
turbo
hybridneon20
not to be rude man, but pulling one of the shims out would create a smaller combustion chamber by bringing the head closer to the block in thus raising compression. iam going turbo so i want to lower it man thanx anyways for your concern.
Per Insurance | Company Reports | Refinance | Car Finance | Mobile Phones
Page generated in 0.39936 seconds with 13 queries
