Old 11-15-2004, 11:41 AM   #1
Main cap girdle, opinions??
BrainOnBoost
I've noticed a couple times flipping through Summit that Ford sells main cap girdles for 5.0s and 351s that connect all the main bearings together for better strength, and I was curious about making one for a 2.2/2.5L, anyone have any input? I don't know how beneficial it would be as opposed to a five-point-slow, but I figured if I was gonna try to build a higher HP/Tourque motor or try to get more rpms out of it, it might help to strengthen the bottom end up a bit. Any input would be appreciated.
Old 11-15-2004, 03:00 PM   #2
My Ride: 84 rampage
Engine: 2.2L T3
I was also thinking about machining something similar. I think your money would be best spent with a longer rod/shorter piston and arp head/main/rod fasteners. Then, if you have $$ left over, an additional girdle couldn't hurt. All of this is based on the assumption you had a common block with the forged 2.2 crank.
Mike Radowski is offline
Old 11-15-2004, 06:15 PM   #3
BrainOnBoost
I'm just getting ideas for future projects, if I did something that would warrant me bracing the bottom end like that I'd have better parts than what I'm using now.
Old 11-17-2004, 01:48 AM   #4
BrainOnBoost
Anyone else?
Old 11-19-2004, 01:21 AM   #5
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
If your gonna do that, then you may as well get a 2.4 block and build that. I think it would be very expensive to try to get one made for our older blocks. It's a great idea, but our bottom ends are pretty stout to begin with.
Andre Parker is offline
Old 11-19-2004, 09:18 AM   #6
If I remember correctly someone on the forum (before the last revision), was looking at using the 2.4 bead plate on a common block.
Daniel Merrill
89acclaim is offline
Debt Help | Debt Management | Mobile Phones | Mortgage | Mortgage Calculator
Page generated in 0.33457 seconds with 13 queries
