12-15-2004, 11:21 PM
#18
My Ride: '89 Daytona Shelby
Thanks for the input bearcat. What I'm trying to do would just involve sleeving the crank's snout. The seals and oilpan won't change.
I stopped by a local machine shop today and they couldn't help me out. They felt like it was too risky. The main sleeve wall is gonna be thin .... around 1.5mm Turning the part from one piece scared the fella. They suggested sweating on a sleeve and turning that down ... but, I think that's overkill.
I had suggested to them another solution that would just involve sleeves.
I've been looking for SS sleeves on-line but haven't hit on anything that is a stock (sort of) part yet. This can be done with four parts, too. A bushing slid on first for the seal surface ... then a sleeve w/keyway to hold the round tooth timming sprocket ... a spacer, inside the sleeve, to make up the snout length .. finally, a taller shaft key.
Being that the thicknesses are so slight, I can't imagine the sleeves upsetting concentrics. Besides, all the outboard parts here are driven with rubber belts. If a machinist familiar with our cranks could chime in on this ... it would be great.
