11-19-2004, 02:37 PM
Originally Posted by The S is Silent
thanks...i just found the mini-mopar site on it. i was looking into the possibility of doing a long rod engine for increased revs, but a dohc head would be needed to get enough power up top to make it worth it. i was just thinking.
realistically, how much would a longer rod setup increase your rev limit, if you could make power up top to make it worth it?
Oh god, don't start another thread on 2.2's and 2.5's, lol! Longer stroke would reduce your top end rpm power, 2.2s rev higher and hit harder in the upper rpm range, 2.5's make more bottom end grunt but run out of steam at higher revs. Now a 2.2L crank with longer rods and custom pistons, wonder what that would do?
