Old 12-06-2004, 12:03 PM   #16
Originally Posted by Jack's Dodge
Head goo. Block good. Turbo bad. Going to replace ater the brake lines.
Your welcome, lol!
Glad you got it figured out. Diagnosing is always cheaper than throwing parts at it.
Old 12-07-2004, 01:02 AM   #17
My Ride: 96 neon
Engine: 2.0L
This is true. Went out to run it a bit. Almost all vac leaks are pluged, but the car stopped smoking for a while Found that odd. Doing another compression test tomorrow, if the rain is not excessive. Brake lines on the way!
Jack's Dodge is offline
Old 12-07-2004, 07:51 AM   #18
Make sure you aren't running it to rich
AfterSchoolHero is offline
Old 12-08-2004, 12:53 AM   #19
Running rich
My Ride: 96 neon
Engine: 2.0L
It was running rich, as the vac lines were all messed up. The MAP was not getting any vaccum. Better now, and smoke is clearing up some. After brakes are fixed, Ill take it for a spin.
Loans | Personal Loans | eHarmony Promotional Code | Debt Consolidation | Hsbc
Page generated in 0.37096 seconds with 13 queries
