Old 12-07-2004, 01:26 PM   #1
Cool A "really" big 4 cylinder dodge
Hey guys,
I just went with another member to look at some old circle track racers parts.
The guy had a get this, 2.7 liter (actually 2680 cc) Chrysler 2.2 stroked short block motor.
Custom billet crank, Carillo rods, dry sump pan, DC strong early style block, billet main caps, ARP studs on head and mains, etc. It made supposedly a bit over 300 horse on the dyno. Not impressed? Ahh, that was without a turbo!!!It was built for a N/A application. It had I believe 12.5 to one compression.
The guys also had two big valve g-heads one milled extensively and one milled about .030.
If you got to have it, it IS available as a package. Not cheap! Put it this way, the crank alone set the guy back $2700 dollars! Then figure in the dry sump pan, the block, the Carillo rods, custom made JE pistons, couple hundred for the ARP hardware, etc. Email me privately and I will forward you a contact and more info.
4 L-bodies is offline
Old 12-07-2004, 01:31 PM   #2
the 2.7 stroker has been out for a while in the neon community, granted a few people have this, but it is avaliable.... scott mohler (neon all motor car) is running a very big 2.6999999 almost 2.7 which is avaliable in a street version with a lot smaller cams, and less power, but still avaliable.
schu725 is offline
Old 12-07-2004, 01:39 PM   #3
My Ride: 2003 SRT-4
Engine: 2.4L 4 cylinder
22dodge built an all motor 2.2/2.5 that puts out 325hp.
2.2/2.5 stuff I've done
brummy is offline
Old 12-07-2004, 03:43 PM   #4
My Ride: 88 Shadow
Feedback: (7)
Do you know the exact bore size and stroke? A 2.5 has a 4.09'' stroke, already insanely long. Lets put it this way, the longest stroke from a small block chevy is 3.75'' in the 400 CID.
moparzrule is offline
Old 12-07-2004, 04:11 PM   #5
the 2.5s rod ratio is already sub-optimal, wouldnt a 2.7 have even a worse rod ratio?
Koreth is offline
Old 12-07-2004, 04:14 PM   #6
like the ability to only rev like a diesel....thats what i thought...
schu725 is offline
Old 12-07-2004, 04:21 PM   #7
what a torquey engine that would be. Thats actually kind of cool. Doesn't strike me as particularly practical, but cool.
Koreth is offline
Old 12-07-2004, 04:26 PM   #8
"this is my stump pulling 2.2..." that would shread tires... i want a 350 wheel torque FWD car...
schu725 is offline
Old 12-07-2004, 05:08 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Sounds like he has around a 4.25'' stroke, thats big block chevy territory!
Old 12-08-2004, 04:57 PM   #10
Yep that's the same guy. The internet sure makes this a smaller world.
Old 12-08-2004, 05:11 PM   #11
Last time I checked I thought the 2.5 common block had a 3.95 stroke?
No, I don't know actual stroke, but rod length I believe was 6.500", the pistons are either .050 or .060 over. In the race blocks there is still lots of meat left over. I am putting together another similiar blocked motor and at .060 over, after sonic testing, there is more thickness left than std. bore production blocks in some cases. BTW the motor I'm putiing together has 4 bolt billet mains! Chrysler had some strange stuff out there.
Old 12-08-2004, 05:22 PM   #12
My Ride: 88 Shadow
Feedback: (7)
Check again LOL.
Read ''1986 - The First 2.5L TBI and 2.2L Turbo II Engines'' in this link-
http://minimopar.knizefamily.net/enginehistory.html
Old 12-08-2004, 05:35 PM   #13
Originally Posted by 4 L-bodies
Last time I checked I thought the 2.5 common block had a 3.95 stroke?.
I guess the key word here is common block not tall block.
Old 12-08-2004, 06:26 PM   #14
1fast1
It's the same stroke.
Old 12-08-2004, 06:29 PM   #15
My Ride: 88 Shadow
Feedback: (7)
Same stroke there big guy. The rods were just longer.
http://www.thedodgegarage.com/turbo_shortblock.html
go to the ''crankshafts and bearings'' section, the stroke is given in MM and thats why I didn't post this link first. Compare to minimopar, 104mm stroke...same.
Mobile Phone | Free Ringtones | Free Credit Reports | Credit Counseling | Credit Cards
Page generated in 0.54260 seconds with 13 queries
