Old 01-18-2005, 07:14 PM   #16
Check your lifters or HLA's. After you run it for a few secs, try to push down with a pry bar or whatever on the lifter side, if it moves down, your lifters are junk. If it doesn't move, then you have issues somewhere else in the valvetrain.
Old 01-18-2005, 07:48 PM   #17
Would a lifter be more of a ticking sound? This sound is more like a deep knock.
I will try what you said and see if that is the colprate.. Thanks
Kevin B.
89Tona is offline
Old 01-21-2005, 12:24 PM   #18
Not to be a dummy but, does the car need to be running to do this?
89Tona is offline
Old 01-21-2005, 01:19 PM   #19
No, you run it then check as the oil pressure pumps them up. Shut it off, wait a bit, say 10 mins then check, if they bleed down, there junk!
Learn PHP free | Debt Consolidation | Personal Finance | Car Credit | Overstock.com
Page generated in 0.30553 seconds with 13 queries
