Old 01-06-2005, 01:49 PM   #31
My Ride: 1987 Shelby Z
1/4: 11.620
Originally Posted by 89acclaim
Well I don't know about putting longer rods in a common block 2.5, they have a short piston as it is. You could do a tall block 2.5, with 2.5 common block pistons, and a rod with a length around 163mm (rough calculation). Just some of my thoughts....
Daniel Merrill
I beleive FM has long rods for both tall and CB 2.5L motors
B.A.P. is offline
Old 01-06-2005, 04:59 PM   #32
They have 6.357" ~ 161.468mm and 6.18" ~ 156.972mm (very close to the 157mm rods on the tallblock), and I will leave it at that.....
Daniel Merrill
89acclaim is offline
Old 01-06-2005, 06:07 PM   #33
I wonder if there is any way to Cryo forged pistons and still get a teflon coating on the skirts and a heat coating on the face
marcoze is offline
Old 04-07-2005, 10:54 PM   #34
My Ride: OMNI GLH
Engine: Chrysler 2.5L
Originally Posted by glhsken
Get a 90 and up common block. They added more "beef" to the rear of the block between the freeze plugs. It is noticibly beefier. Reeves had his block crack there all the way across at about the 375whp 425 ft lb mark.
I'm not sure if the block broke because of the power, or if the crack was already there and I just finished'er off. This is the same block that I found a bulge in the front of it right above the crank and oil pump sprockets.
89 casting and later blocks have the area between the freeze plugs in the rear beefed up and also the rear bellhousing tab is beefed as well (where it always cracks at).
Reeves is offline
Old 04-07-2005, 11:08 PM   #35
I have pushed one around on a cart, if that's what you're asking for
1985ShlbyChrger is offline
Old 04-09-2005, 09:35 PM   #36
Recryo
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
http://www.cryopro.com/engine.htm
I=ca=haul=my=parts=there=iMywifejustspilledmycokeo thekeyoard
looneytuner is offline
Mortgage Calculator | Guitar Lessons | Verizon Ringtones | Bankruptcy | Cell Phones
Page generated in 0.35045 seconds with 13 queries
