12-29-2004, 06:10 PM
My Ride: 1987 Shelby GLHS 189
If there are good crosshatch marks, don't bother with the hone. Done it numerous times. Last engine I did it to the rings seated within 5 miles (22 psi will do that) and the engine dynoed at 289 whp.
12-29-2004, 06:11 PM
Been there, done that. Just make sure as noted to keep everything clean, use a ball hone and I used lots of brake cleaner, carb cleaner and engine degreaser to clean the bores and crank throws. Try to buy the one piece oil pan gasket, its so much easier putting the oil pan back on.
12-29-2004, 06:23 PM
LOL... Good one!@!! (note the engine held!!!, damn trannies!!!)
You better come to SDAC this year!!! (brews await!!)
12-29-2004, 09:16 PM
My Ride: 2004 SRT4
Engine: 2.4
get some rubber hose to put over the rod bolts to help keep from knicking the crank. It would be nice to be able to wash the cylinders as there will be small debris inside the cross hatch. I use a bottle brush and soapy water and then a good rinse and then some oil on the cylinders.
12-29-2004, 10:25 PM
My Ride: '89 Daytona Shelby
Originally Posted by Andre' Parker
get some rubber hose to put over the rod help keep from missing the SDAC.
... whaaaa
12-29-2004, 10:36 PM
#12
My Ride: '87 Omni
Engine: Dodge 2.2
Hey, I'm doing the same bit in my omni right now, chaging piston and rods while engine is still in the vehicle. Would you suggest cutting out the ring ridge before a quick scuff with the hone so the new rings won't tap it at the top and make noise/possibally break the rings? And yep, the ring ridge isn't much, but its still there = worn holes, but the origional hatch is still visibal and i'm not expecting much of the engine. We'll call it a learning experiance
Now, if that pesky FM would send my pistons already, its been like a month+ and i called them, and god the old run around. Things aren't looking good.
12-30-2004, 09:23 AM
#13
I didn't ...
Hey if it's only been a month since you ordered your pistons, you've got plenty of time yet! HAHA!!!
Just kidding
12-30-2004, 11:20 AM
#14
Only a month, muhahhhahhahhah, I waited almost 7 weeks for a SV and Elbow they had in "stock".
Anyhow, I would remove the ridge, new rings have a sharp edge and it could possibly damaged the new rings when running. Also, could damage a piston also when removing them.
12-30-2004, 11:29 AM
#15
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
If the ridge is just carbon, it will come off with paint thinner. If the ridge is metal, you might want to check your piston to wall clearances.
