12-29-2004, 06:03 PM
Weight variance in T2 Rods
My Ride: 86 GLHS
Engine: 2.2 Turbo Intercool
I recently purchase "New T2 Rods" from another member on this board.
I got the rods, but they appear to be Reman.
I weighed them and these were the numbers
.70 kg
.70 kg
.71 kg
.71 kg
My concern is that the .1kg variance will cause my engine to prematurely fail.
Should I be worried over this?
12-29-2004, 06:12 PM
No!
12-29-2004, 06:38 PM
My Ride: 86 GLHS
You are exactly right.
That is why I listed it like that... because my scale is only accurate up to 10 grams....
therefore, I would have had to list it like this:
700 grams
700 grams
701-710 grams
700 grams
Thanks...
I just know that I want my engine as balance as possible and, worst case scenario, lets say the rods were exactly this
691 grams
691 grams
710 grams
691 grams
Should I be worried?
12-29-2004, 06:55 PM
700 grams
700 grams
701-710 grams
700 grams
Thanks...
691 grams
691 grams
710 grams
691 grams
I don't know off the top of my head what a good spec would be, but I think 19 grams might be getting high - it's about 2/3 of an ounce.
If you can find a "piston matching" weight spec, that should give you a better idea.
12-29-2004, 09:12 PM
My Ride: 2004 SRT4
Engine: 2.4
Can you borrow one from someone that reads a little lower?? You can sand on the bottom of the cap which is where we sanded them at the shop I worked at. The closer you get everything to the same weight, the more power you can make because you can rev a little higher and not have as much bad harmonics.
12-29-2004, 10:40 PM
My Ride: 86 GLHS
Thanks, that's some good advice.
I will try that out and see how much of the weight I can take off of the heaviest ones.
I didn't know how much the weights come into play, but I think if I take to two heaviest and offset them against each other it should help.
12-29-2004, 10:53 PM
My Ride: '87 Omni
Engine: Dodge 2.2
The bottom of the cap is called the balancing pad. Remove material evenly and carefully there and try to get the rods close to each other. A 4cyl relys on equal piston/rod weight to balance the engine.
When i get my t2 rods in i'm going to balance the rods as close as i can get them (hopefully under 2grams from each other) and the same for the pistons, if they ever come.
From what i remember talking to some engine builders, they try to get balanced parts down to +-1 gram vairance between parts. I think thats being quite picky, but then again when can one ever be too picky?
12-30-2004, 02:17 PM
My Ride: 86 GLHS
I suppose waiting until I get pistons would be beneficial... before I start taking material off any of the reciprocating mass.
I bought a set of used (but nice condition) stock cast pistons.... as I still haven't decided whether to do a quick fix and use those... or wait till I can fully build the motor how I want it.
Or... if I should wait a lil onger and get the forged pistons.
I figure until then, keep reading the board.
But the more I read the more I find evidence to support either or.
Things such as... 2.2 stock pistons are plenty strong.
Or putting the forged piston into the T1 block adds stregnth...
Or, also, so many good parts coming onto the TD market... like TU SS header.
Sweet.
But all the stuff I want adds up to serious $$$.. and I just want to be driving asap.!
12-30-2004, 03:39 PM
#12
Just becareful balancing rods, I have heard that they weigh both ends of the rod, and also spin balance them with the pistons. I would be call a machine shop that balances them or have them balance everything, its cheap, around $100, and cheaper still if you screw it up and then your whole engine vibrates badly or wears out prematurely.
