Old 01-05-2005, 02:21 AM   #1
Common Block
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
If I were to come up with a common block, will it bolt into my '87 "J" body as the original one did? Is the block the same for turbo and N/A configurations?
Moparmonster is offline
Old 01-10-2005, 04:25 PM   #2
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
Should work. I bolted a common block into my 87 daytona. It was an N/A block. I just cross drilled it and drilled an oil return hole and that's the only difference between common block N/A and turbo.
cawcislo is offline
Old 01-12-2005, 03:01 AM   #3
Will a C/B work with my '85 "G" head too?
Old 01-12-2005, 10:48 AM   #4
G head will work, you will lower compression a little. The engine will bolt up, I have a 90 common block mated to a 87 520 in a 84 voyager. I didn't have any problems installing it.
Turbo84Voyager is offline
Old 01-12-2005, 11:13 AM   #5
Head Bolts
In some cases the early 287 G head might not fit depending on the Bolt hole centers. The common block has 11mm head bolt holes and the early blocks had 10mm. If you run into a problem just drill out the hole to a larger dia in the head.
~ Mike
Turbo Dynamx, Inc.
Mr P-body is offline
Old 01-16-2005, 11:37 PM   #6
Yes, I plan to have the holes tapped to 11mm, in addition to getting the intake and header port matched and a three angle valve job. I don't expect to pick up much horsepower, but I'm not leaning in that direction anyway. I want efficiency and reliability out of the engine. I also found another '87 Lebaron 'vert 2.2 turbo I for $475. I think I can get it cheaper, and that way rebuild the engine and swap it straight out for the old one, like I'm doing with my truck.
Old 01-17-2005, 03:46 AM   #7
Machine work
Let me know if you need any of those machining services performed. We could work out a package deal for you.
~ Mike
Turbo Dynamx, Inc.
contact@turbodynamx.net
Mortgage | Online Advertising | Loan | Debt Consolidation | Loans
Page generated in 0.53321 seconds with 13 queries
