Old 01-15-2005, 07:12 PM   #1
ARP Head Stud Tork?
Location: Down back in the shack with the moon in the door
My Ride: 89 Daytona
Engine: 2.5L TII
I know it has been asked but I can't find it. What is the standard way to tork down ARP head studs? What is the final tork lb amount?
Bad Vibe is offline
Old 01-16-2005, 03:07 AM   #2
My Ride: 90 stang, 86 stang
Engine: T.T521", nitrous351w
70 lbs if i remeber rt same pattern as chryslers i think its tourqe to 45 then 45 agian then 70... thats how i do mine and then start it let i warm up fully and then cool off and re-tourqe and then agian after a few hundered miles....
igotaneed4speed is offline
Old 01-16-2005, 10:10 AM   #3
My Ride: 1987 shelby csx
Engine: 2.4 dohc conversion
Most guys torque to around 87 ft lbs make sure you pre stretch the studs which means torque 4 to 5 times and loosen.Otherwise you may have head floating problems after they are stretched they will quit snapping while torqueing.
kedavis is offline
Old 01-16-2005, 09:07 PM   #4
My Ride: 89 Daytona
Engine: 2.5L TII
Thank you.
Bad Vibe is offline
Old 01-16-2005, 09:34 PM   #5
My Ride: td
so is it just 87, or is it like the stock ones where you go to 65, then 1/4 turn?
Geoff is offline
Old 01-16-2005, 11:11 PM   #6
Yea you can do it in a sequence of three.
kedavis is offline
Old 01-17-2005, 06:39 AM   #7
My Ride: 88 Dodge Shadow
Engine: T-III Power
i thought since the stock bolts were torque to yeild that the 1/4 turn was to stretch them?
wouldnt that mean this doesnt apply to the ARP's? i can't imagine the ARP's stretching if you can reuse them. seems like they would be no good pretty quickly if they stretched like a stock bolt.
iniviate is offline
Old 01-17-2005, 10:11 AM   #8
ARP Torque Specs
My Ride: Shelby CSXT
Direct from ARP
Here are the correct Torque Specs for ARP Head Bolts too.
Torque for M11 bolts using ARP Moly Lube is 75 ft/lbs.
Torque for M11 bolts using 30wt engine oil is 90 ft/lbs.
Torque for M11 studs using ARP Moly Lube is 70 ft/lbs.
Torque for M11 studs using 30wt engine oil is 85 ft/lbs
CSXT404 is offline
Old 01-17-2005, 11:28 AM   #9
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
On aluminum heads ARP said 65 with moly lube.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 01-17-2005, 11:34 AM   #10
I talked to tech at arp when I had a head floating problem when they are new they need to be torqued 5 times to pre stretch before final torque after that it doesnt need to be done again.
kedavis is offline
Old 01-17-2005, 12:22 PM   #11
No, they are not like the stock head bolts, they are not torque to yield.
The instructions I got with mine are
ARP lube, aluminum head 65ft/lbs
ARP lube, cast head, 70ft/lbs
30Wt oil, cast head, 85ft/lbs
So I guess do the math for 30wt oil with alumumium head. They don't list that reading. For the price of a tube of ARP lube, not worth using oil, and your guaranteed a proper reading and no stiction on the bolt head and washer.
Note, I run mine at 70 ft/lbs at 29 psi and zero issues with a MP gasket. I saw on here, some guys are cranking the torque up to 80 or even 90 ft/lbs on high HP engines.
Mortgage Calculator | Debt Consolidation | Debt Consolidation | Movies download | Remortgages
Page generated in 0.38630 seconds with 13 queries
