01-18-2005, 12:10 AM
what pistons should I use?
My Ride: 1987 "Supertona"
It looks like I am going to have to bore my 88 common block 2.2, what should I use for pistons. Keep in mind that I will be using all stock internals, and pretty much keeping thw whole engine stock.
Prices, and where can I find them?
-kaleb
01-18-2005, 03:36 AM
My Ride: 90 stang, 86 stang
Engine: T.T521", nitrous351w
.020 mahles from fwd performance there the same as the stockers just .020 or .040 depending the condition of ur sleves'
01-18-2005, 08:31 AM
Authorized TD Vendor
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
If you can get the Mahles in the size you need, they are a very good piston and they are priced good as well. FWDP has some at 281-288-4411
Wallace
91 Spirit R/T
11.686@120.89 mph
01-18-2005, 08:46 AM
My Ride: Shelby CSXT
-kaleb
89 & up are Common Blocks. Do you have a block off plate? What kind of car do you have? 88T1 Rods are crappy. Upgrade to T2 rods or True CB rods. They are beefier. If you got the cash go Wiesco Forged pistons w/ T2 rods and stock crank. You will be good for some serious HP!
01-18-2005, 09:16 AM
My Ride: 1987 Shelby GLHS 189
If you are doing a block, might as well go forged. I would get .020" oversized if your block can be machined for it. I would avoid odd sized like .010" and .030" as rings must usually be adopted to fit.
01-20-2005, 08:58 PM
My Ride: 88 Shadow
If you can afford it go forged, however they are 3 times as much. I just went with the Mahles. I have however already cracked one and had to replace it but this only happens if you try to run 22 PSI with the stock swirl head (which had been milled atleast twice) on pump gas  . Now that I'm running a G head it's back to 22 PSI  .
01-30-2005, 10:04 AM
My Ride: 89 caravan es t1
Engine: 2.2 garett/ 3 inch e
Ken what kind of prices on wiesco piston and rings for a com block. It has 20 over now with unknow pistons in it now and will they work well in a daily driver?als
01-30-2005, 11:12 AM
Yes, that is the price. Availability is why TU now handles them. Before, each was a special order and took 4-6 weeks to get. Now Chris stocks them on hand in the more common sizes. Both 2.2 and 2.5L. Prior to last year, to get pistons rings pins and keepers was about 550-600 total.
The Wiseco's with rings are now roughly twice the price of stockers and good rings. That pays for the headgasket, fluids, replacement pistons, rings,and most importantly TIME caused by just 1 Mahle cracking and having to be replaced.
01-30-2005, 12:27 PM
My Ride: 88 Shadow
I know this all too well
02-04-2005, 08:55 PM
My Ride: 1986 GLHS #065
Engine: 535hpAluminumLongRod
1/4: 11.921
JEs T2 rods. If u dont plan on making much over 400whp u wont ever have to worry about them.
