03-08-2005, 02:28 PM
#32
Check this thread, someone on here sells them otherwise ask them, theres only a few stores that sell them.
REally on the hone. I got specific instructions and I phoned them and I had to follow them to the letter. The cross hatch is specifed as the hone at 280 like you. You use there lube or WD40 to assemble.
03-08-2005, 07:33 PM
#33
My Ride: '89 Daytona Shelby
Originally Posted by turbovanman
It depends on the application. At first, he had me with reg top ring, then gapless 2nd.
Since our top rings take so much heat wouldn't the second ring would be the best choice?
What was his thinking on changing to a gapless top for you instead?
03-08-2005, 08:27 PM
#34
Honestly, can't tell you. He was mumbling then you could hear him tapping away on his computer after I made sure to tell him that is was turbocharged and will be running high boost but it is a daily driver.
03-08-2005, 09:16 PM
#35
... uh-oh.
03-08-2005, 09:20 PM
#36
My Ride: '87 Omni
Engine: Dodge 2.2
I was thinking if I ever build a real engine, I would use a chrome top ring and gapless second, as the chrome ring will take some serious abuse/heat while the pressure that gets by it will be more than enough to seal the second ring, Remember,! combustion pressure seals the rings on the wall, the tension only is there to keep them touching. Thats why in some drag cars you see gas holes in the piston, drilled from the piston top to down behind the top ring, to help combustion pressure get there sooner and seal the ringer sooner and harder. If you use a gapless top ring, and they really perform as well as advertised, a low tension or no bottom ring seems like it would be the next best thing to do, as it may not be doing much more than scraping whats left of the oil.....of course in a street motor, i think i woudl always run a full ring package, oil consumption is annoying.
03-08-2005, 10:49 PM
#37
... uh-oh.
What?
03-08-2005, 11:01 PM
#38
Did he send you two sets of rings .. one for the high booster and another for the dd?
j/k ... just made me chuckle when you said you could hear him pounding the keys looking for the right combination. ... your van's a TS testing lab.
I don't know ... everyone I ever saw run these used them in the 2nd slot. Being the more expensive ring in the set. ... of course the cheap Pollacks I hang with were probably just hedging their bets.
03-09-2005, 12:02 PM
#39
Probably,
But will find out in a month or so what happens. Just waiting my block prep and my other goodies.
03-09-2005, 05:34 PM
#41
All I remember is Car Craft or Hot Rod had an N/A small block Chevy. They ran it with reg rings and it had like 8-10% leak down, can't remember the HP. Then they put Total Seal in and broke it in, did the dyno runs to simulate some wear and tear, less than 2% leak down and picked up like 20hp. I will try to find the article.
03-09-2005, 10:12 PM
#43
My Ride: '87 Omni
Engine: Dodge 2.2
I would think that they would have larger effects on lower-rpm engines where the piston is acted on for a longer duration.......but maybe i'm just full of theory, or .... you get the idea
