Old 01-26-2005, 04:53 PM   #1
Oil Pick-up mod
My Ride: 96 neon
Engine: 2.0L
Just removed the oil pan to do some cleaning. Seemed a good time to improve oil flow. Question is, can you remove too much from the pick up? And can this cause problems? Used a dremel, took out about half. Thanks.
Jack's Dodge is offline
Old 01-26-2005, 05:05 PM   #2
I would just remove the tin restrictor in the pickup opening, thats all I did with mine. Nice easy flow into the pump. Leave the screen in place though.
Old 01-26-2005, 05:22 PM   #3
only problem will be if you don't clean *absolutly* all of the metal that the dremel flung everywhere. After you think it's clean, clean it another 3 times.
89daytonaTII is offline
Old 01-26-2005, 05:26 PM   #4
There is no metal to grind, you pull out the tin with some tin snips.
Old 01-26-2005, 05:51 PM   #5
yeah that's the way I would/did do it. but.....
Old 01-26-2005, 05:55 PM   #6
My Ride: No slicks Omni
While it's apart look at the block mounting surface.
The hole in block is "smaller" than the tube's base and
there is room to open up block a bit.
russ jerome is offline
Old 01-26-2005, 06:10 PM   #7
I was going to say that but I figured, thats a better mod for when the block is stripped.
Old 01-26-2005, 07:27 PM   #8
My Ride: 96 neon
Engine: 2.0L
Have not seen you around in a while. You been avoiding my threads I removed 80% of the tin, so all should be well. Having fun enough redoing vac lines.
Old 01-26-2005, 08:12 PM   #9
Originally Posted by Jack's Dodge
Have not seen you around in a while. You been avoind my threads I removed 80% of the tin, so all should be well. Having fun enough redoing vac lines.
Where have you been, lol! I've been all over the place, lol!
Old 01-29-2005, 11:22 AM   #10
My Ride: 99 Cummins
Engine: 5.9
Images: 6
Anyone have experience with teh pickup tube that is 100% mesh sock?
Im using it now, and i think its from my original 86 TBI engine.
Timmay2 is offline
Old 01-30-2005, 05:42 PM   #11
My Ride: '87 Omni
Engine: Dodge 2.2
The more you remove, the more important it becomes to have the entire sump covered, or cavitation will result.
Putter is offline
Old 01-31-2005, 01:30 AM   #12
My Ride: 96 neon
Engine: 2.0L
Best get moving on a baffled oil pan. Thanks for the tip Putter.
Pacotes Carnaval Salvador | Jewelry Store | Mbna | Loans | Car Loan
Page generated in 0.41510 seconds with 13 queries
