Old 01-29-2005, 07:43 PM   #1
Oil drain tube
Will Martin's Avatar
My Ride: '92 IROC R/T
Engine: 2.2 135ci TIII 16v
I'm changing to a TBI header and I'm wondering how to plug the stock oil drain tube on the block. How have you guys done it? Thanks.
'01 Maxima SE
Will Martin is offline
Old 01-29-2005, 09:43 PM   #2
My Ride: 88 Shadow
Feedback: (7)
I found a rubber cap (like a big vacuum plug) and hose clamped it, just look around at advance auto or autozone.
moparzrule is offline
Old 01-30-2005, 10:57 AM   #3
If you want it done nicer and tidier...
The tube is just pressed into the block, a big pair of pliers and you can twist it out. Find an appropriate sized plug (brass, or the hex style plugs on the water box on the head - anything like that, tap the block and insert plug.
Mike M is offline
Charity | Loans | Secured Loans | Balance Transfer Credit Cards | Mortgages
Page generated in 0.30067 seconds with 13 queries
