Old 02-18-2005, 12:16 PM   #46
Originally Posted by Koreth
Okay. Well, since I was planning a complete disassembly of the shortblock that would include removing the intermediate shaft as well (unless that requires special tools beyond my reach right now). So I could keep the intermediate shaft bearings at my place so they aren't destroyed by the hot-tanking, or is replacing them cheap insurance, like the oil pump and pickup?
You need a puller to remove the bearings, once removed, there junk as there a press fit. You can have the machine shop put new bearings in for you!
Old 02-20-2005, 05:57 AM   #47
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
Originally Posted by slothman
Honing is for proper break in of your rings.
Not true. Honing creates shallow grooves that permit a small amount of oil to stick to the cylinder walls. Too much oil in the cylinders creates smoke and low octane problems; properly honed cylinders allow just enough oil to lubricate the pistons.
Moparmonster is offline
Old 02-20-2005, 07:02 AM   #48
My Ride: '92 Daytona Iroc
is it needed to replace the intermediate shaft bushings/bearings?
btw. my motor is in parts because i spun a rodbearing due to massive oil loss.
so how can i see, if they're junk?
Austrian Dodge is offline
Old 02-20-2005, 03:46 PM   #49
My Ride: 85 glh turbo
Engine: 2.2 turbo
1/4: 11.510
I replaced mine while the engine was still in the car. Just line up the oil holes and carefully TAP it in.
The way I saw that my bushing was bad, the shaft had a lot of play when installed. It should be a snug fit but still be able to rotate without much resistence.
85glht is offline
Prepaid Credit Cards | Optical Illusions | Problem Mortgage | MPAA | Free Credit Reports
Page generated in 0.31196 seconds with 13 queries
