Old 02-02-2005, 09:29 PM   #1
Piston pin Size
Mr Overkill's Avatar
My Ride: 90 daytona shelby
Ok i see people selling the pistons with the bigger .927? pins
Are they stronger compared to the .901s or do they actually weaken the small end due to having to bore out the bushing a lot
Just asking because im in the market for pistons AGAIN!!!!!
Mr Overkill is offline
Old 02-02-2005, 09:40 PM   #2
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Well, back in the day the deal on the stock pins was something about pin flex and hammering out the c-clips on the T2 pistons. The problem is that if you go with the Chevy pin, you have to bore out the bushing on the rod. The problem with that is that the bushing is brass-dipped steel, not solid brass. If you put a solid brass or bronze bushing in there, it is too thin and tends to fall apart. So, you have to bore out the end of the rod to put in a bigger bushing.
All that said, I have not heard of anyone breaking the end of their rod off. Anyone? Also, I am not sure how true the pin-flex problem is in the first place.
minimopar is offline
Old 02-02-2005, 10:11 PM   #3
exactly mini If the .901 are fine then thats what i will get
I have been told that the reason the .927 are being offered is because thats the standard chevy bushing so it saves the vendors or the manafacutres money
Old 02-03-2005, 11:40 AM   #4
Engine: 2.5 turbo
That's what I heard also. When I bought my venolias the bushings had to be honed just a little for the .901 pins.
slasky is offline
Old 02-03-2005, 02:18 PM   #5
My Ride: 84 Chrysler Laser
Engine: 92 com. blk. 2.2
Why not use a smaller, stronger, and lighter pin? I use a .866 pin, hundreds of runs, no problems. Warren
2.2=8 is offline
Old 02-03-2005, 09:08 PM   #6
gonna go with the .901 its still bigger than stock but not to the point that your cutting a lot out
Old 02-03-2005, 09:16 PM   #7
My Ride: 88 Shadow
Feedback: (7)
.901 is stock, did you mean .912? JE pistons use a .912 pin.
moparzrule is offline
Old 02-03-2005, 09:20 PM   #8
oh i thought .901 was the next size over stock well then im gonna go with the stock size
Dont see a problem with that not gonna go with je tooooo many bad reports
Old 02-03-2005, 09:35 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Wha? JE's are good, where id you hear otherwise? I know venolia's suck, but JE, Wiseco, and ROSS pistons are all pretty good.
Old 02-03-2005, 10:32 PM   #10
trying to rember where i saw it about the je's
i will post it when i find it
Old 02-07-2005, 06:53 PM   #11
My Ride: '88 Shelby Z TII
The reason for the .927 pins was to help with piston rock at TDC & BDC due to the rod angles. It gives the piston a larger fulcrum to pivot on and therefore keeps it centered in the bore better, and reduces some of the side thrust. At least this is the theory that was handed to me. I agree on the lighter pin thing though...I will look into that for Über motor when the time comes...
Reaper1 is offline
Old 02-07-2005, 06:59 PM   #12
thanks reaper i just think the .95 are 2 big
Old 02-07-2005, 07:07 PM   #13
^ .95? Never heard of that being used in one of our engines. I too think that is too big and "could" cause issues, not to mention adding weight to the reciprocating mass...not a good thing.
Reaper1 is offline
Old 02-07-2005, 07:10 PM   #14
lololol
sorry i hit the wrong key
Old 02-07-2005, 08:00 PM   #15
Ahh...that happens
Reaper1 is offline
Debt Consolidation | Debt Consolidation | Guitar Lessons | Free Advertising | Fast Loans
Page generated in 0.56796 seconds with 13 queries
