Old 02-09-2005, 02:05 PM   #16
My Ride: 1987 Shelby Z
1/4: 11.620
Sooo, why not JE's? Just curious...
B.A.P. is offline
Old 02-09-2005, 02:13 PM   #17
My Ride: 84 Chrysler Laser
Engine: 92 com. blk. 2.2
I don't think there is anything wrong with JE's, just don't know if you can get them that light without braking the bank.
2.2=8 is offline
Old 02-09-2005, 02:18 PM   #18
My Ride: 1987 Shelby GLHS 189
No one in this thread brought them up..
glhsken is offline
Old 02-09-2005, 02:29 PM   #19
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
They were brought up in the previous thread.
Need some input Machine shop screw up !!!
They are pricey for what you get, but that's FM.
minimopar is offline
Old 02-09-2005, 02:34 PM   #20
Engine: 1987 2.2L
In regards to Gary's coment about the Venolias...it is interesting. My machinist thought highly of them, as they were very close in dimensions and weight. I won't be using them again though. Too loud.
On the subject on skirts (piston skirts, that is): what is the deal here? My Venolias were 2.2L, but had basically no skirt. I'm sure that contributes to the noise. Are the JE/Ross/Wiseco pistons skirtless as well? That would be annoying.
Old 02-09-2005, 02:40 PM   #21
My Ride: 88 Shadow
Feedback: (7)
moparzrule is offline
Old 02-09-2005, 02:42 PM   #22
does anyone know the measurement of a wiseco (stock bore)? i have an 89,000 mile motor with little to no taper or out of round, would like to keep it standard bore if possible. i have a dial bore gauge, so i know the meausurement of my bores, just wondering if, when they are honed, they will be beyond the .035 clearance wiseco calls for.
mo' parts is offline
Old 02-09-2005, 02:52 PM   #23
what DOES a hone do anyway besides scratch up the cyl wall with all those crosshatch marks? and what kind of changes does honing usual make to the dimensions of the bore?
Koreth is offline
Old 02-09-2005, 04:06 PM   #24
Engine: 1987 2.2L
Very little change, I suspect, but it depends how long you do it for. You are basically setting up a surface that is proper for ring break-in. I think the tool on the boring machine leaves a slightly grooved surface, so they maybe have to hone a little more than someone doing a re-ring.
Old 02-09-2005, 04:26 PM   #25
My Ride: 88 Shadow
Feedback: (7)
I believe honing at a machine shop can take up to .005'', someone correct me if I'm wrong! But I believe bottle honing wouldn't really take anything off.
Old 02-09-2005, 04:29 PM   #26
Depends on the hone, if you use a bar stone type, you can remove alot of metal, some use this method to get exact bore clearances. The ball hone, not much if any.
I have some JE's going into my next shortblock for my 2.5 and they look very stout, nice skirts-same as the stockers. Bore clearance is only .004" so it shouldn't sound like a diesel when cold. I will get one weighed for comparison. Oh and there are no sharp edges, they have all been rounded off.
The only reason I got these was Venolias I heard way way to loud and .007" bore clearance is ridiculous and Gary didn't have any .020 Ross pistons,
Old 02-09-2005, 04:40 PM   #27
My Ride: 88 Shadow
Feedback: (7)
I use the bottle hone, it's real easy and hard to mess up! LOL
Old 02-09-2005, 04:45 PM   #28
Engine: 1987 2.2L
I would love to see a pic of a 2.2L Venolia, JE, Wiseco, and Ross all side-by-side.
Old 02-09-2005, 04:50 PM   #29
[IMG]http://********************/shop/images/Wiseco%20Pistons.jpg[/IMG][IMG]http://********************/shop/images/Pistons%20cat.jpg[/IMG]
not great shots.. but at least pics
glhsken is offline
Old 02-09-2005, 04:53 PM   #30
RE PISTON skirts
looneytuner's Avatar
My Ride: 85 GTS, 3 87 GTS, 89
The PISTON skirts have 2 functions. Minimize piston slap and bore wear, AND heat disipation (heat transfer). The bad is extra weight. Aluminum transfers heat quickly so the extra skirt (PISTON) should make a big difference.
"Incompetence is a state of mind caused by too many years on computers".
Me, not you Russ
looneytuner is offline
Loans | Image Hosting | Mortgage Broker Leads | Bankruptcy | Guitar Lesson
Page generated in 0.81133 seconds with 14 queries
