Old 02-09-2005, 11:09 AM   #1
O-ring it or not???
I'm building a 90' 2.2 CB with FM Enforcer II head, I plan on running 20-22psi with a hybrid turbo. Anyone have their block O-ringed? Any problems with it?
glhs#064 is offline
Old 02-09-2005, 12:42 PM   #2
My Ride: 1986 Plymouth Horizo
Engine: 2.2 Turbo
Don't O ring it. Since the advent of MLS gaskets, many people, including GN and Mustang guys, who used to O-ring their stuff, have stopped doing so.
contraption22 is offline
Old 02-09-2005, 01:45 PM   #3
My Ride: 86 glh-t
Engine: stock 2.2
only problem with mls style gaskets is they DO leak boost,cylinder pressure between the layers. sce has released there new titan copper gasket. it's a copper gasket that has embosesd silicon around all the oil & water holes. no more common leaks that were a problem.
scot
xjjunkie is offline
Old 02-09-2005, 05:45 PM   #4
Engine: 2.2 Turbo
I have a cometic on my car with no leak issues. Also many OEM cars are using MLS gaskets. I have never heard of the problems you speak of.
Old 02-09-2005, 08:46 PM   #5
If your head and block is straight, running new head bolts or using studs, MP gasket, correct tuning, you will have no issues with NOT o-ringing the block.
Old 02-09-2005, 08:56 PM   #6
ohiorob's Avatar
My Ride: 83 shelby charger
Engine: 2.4 DOHC
1/4: 10.066
yes...don't waste your money.
ohiorob is offline
Old 02-09-2005, 09:34 PM   #7
My Ride: 1987 Shelby CSX #694
Engine: 1987 2.2L
Once it's o-ringed, you can't go back. Then you are stuck with copper gaskets or NOS MP gaskets for o-ringed blocks.
minimopar is offline
Old 02-10-2005, 12:45 AM   #8
My Ride: 2000 GMC Sierra
Engine: 5.3L V8
Don't o ring it
cybermrc is offline
Old 02-10-2005, 07:45 AM   #9
Ok, ok I guess I shouldnt O-ring it. So which head gasket should I run?
glhs#064 is offline
Old 02-10-2005, 08:32 AM   #10
My Ride: 1987 Shelby GLHS 189
Well.. I've seen an mp with mp bolts take 468ft lbs of torque with NO ISSUES...
glhsken is offline
Old 02-10-2005, 09:08 AM   #11
I only want to build it once, so I'm gonna use ARP studs in everything. So you think I should use MP head gasket?
glhs#064 is offline
Old 02-10-2005, 09:33 AM   #12
I'm shooting for 375-400whp. I'll be using one.
glhsken is offline
Old 02-10-2005, 09:41 AM   #13
I do understand most people's opinions.
I was running a MP 006 Headgasket in my car last couple years.
Never really had a problem blowing gaskets (even at 34 psi)
But with that being said:
My new block will be "o-rung"/"o-ringed"
The head has a receiving grove in it.
Complete with a custom made copper headgasket.
Head studs have been increased to 1/2"
I have been told that I will never have to take the head off for the life of the motor.
DakotaKid is offline
Old 02-10-2005, 10:24 AM   #14
For a street car, I would like somewhat of a fuse. Look at Reeves. He screwed up. Lost only a gasket. That was after tons of passes and some street driving. What would have happened if he HAD been running an imoveable head gasket. Bent rods?? Broken forged slugs?? Head damage from peices flying around in the combustion chamber??
Give me a fuse... short blocks aint cheap when done right.
glhsken is offline
Old 02-10-2005, 11:22 AM   #15
See post #5
Good points Ken, thats why I left the stock rear band strut in my tranny, someone told me it was a fuse, rather than break the band,
Debt Consolidation | Credit Cards | Car Loan | Debt Consolidation | Debt Consolidation
Page generated in 0.40738 seconds with 13 queries
