02-14-2005, 03:21 PM
Originally Posted by finallall
Thanks Minimopar that answers my questions. I will give it a go.
Also is ball honing OK or is there another better way to do it?? I was told I can buy/borrow a honing machine for cheap and do it myself. Any advice on that? Any problem when honing with the engine in the car?
Thanks again, Alex.
Ball honing is the best way, I don't like the bar hones, I have had too much trouble with rings not seating.
If you can afford to buy a honing machine, you must be rich,
Seriously, there expensive and you have to strip your block down. Good luck.
As Russ says, make sure to cover the crank with a rag so as not to cover the journals with grit and clean your bores etc well after your done honing.
