Old 02-20-2005, 01:23 AM   #16
Feedback: (32)
Originally Posted by desertsnake1991
Chrysler copied the balance shaft idea from the similar sized engines in the Porsche 944...the engineers put those things in there for a reason boys and girls! Mine runs soooooo smooth with them, and the idea of that car cruising at 140+mph over here without them would be ludicrous...other (safer/saner) ways to free up HP, and more than that, maintain drivability and reliablity...
I hope you're only talking about your TI because your TII don't have them.
tryingbe is offline
Old 02-21-2005, 01:00 AM   #17
My Ride: 89 Caravan
Engine: 2.5 Turbo
are there any pans baffled from the factory that will work?
10-15 horse seems like a lot when we are talking balance shafts. in my rwd car i switched from a 727 trans to a 998. from all thats written about these transmissions, i should have freed up almost twice that amount. well the car ran the exact same mph indicating no h.p. saving. the e.t. dropped due to the better launch with the 998's looser converter.
amx1 is offline
Old 02-21-2005, 12:31 PM   #18
Chrysler used to sell one but no longer. You can make your own, or use an earlier shallower oil pan or have someone make it for you.
I am building my old engine with forged internals and getting the balance rechecked, I think they screwed up. Maybe I will dyno it, then take them out and redo it, maybe, lol!
Old 02-22-2005, 01:01 AM   #19
My Ride: 89 Caravan
Engine: 2.5 Turbo
i would assume the pick-up requires changing if you go to the shallower pan? is this pan a 2.2l pan, and from what years? there is a bunch of them in wreckers out here.
amx1 is offline
Old 02-22-2005, 01:10 AM   #20
My Ride: 1991 Daytona Shelby
Engine: SOHC 2.5L
You must use a CB (89+) 2.2L pan, turbo or not, as well as a turbo 2.2L pick-up, circular with no bracket, the 2.5 is rectangular.
91DSX is offline
Old 02-22-2005, 09:24 AM   #21
My Ride: 89 Caravan
Engine: 2.5 Turbo
thanks.
amx1 is offline
FHA Loans | Credit Cards | Cheap Hosting | Bankruptcy | Adverse Credit Remortgage
Page generated in 0.65526 seconds with 13 queries
