Old 02-18-2005, 07:27 PM   #1
Balancing Shafts
My Ride: 93' Turbo Duster
Engine: 2.5L T2
Images: 14
Are there balanceing shafts in 2.5L turbo enignes? And can you remove them like in a TBI to free up some hp?
d_snook6 is offline
Old 02-18-2005, 07:30 PM   #2
Yes and Yes!
Old 02-18-2005, 07:33 PM   #3
Engine: 2.5L T2
Images: 14
is it worth doing?
Are we talking a noticable gain here?
d_snook6 is offline
Old 02-18-2005, 07:37 PM   #4
People say they notice a little gain in power, and the engine the same or a bit rougher. I put mine back in, I am running MP motor mounts and the steering wheel would move an inch at idle with the A/C on. Much nicer now and I don't notice any difference in power.
Old 02-18-2005, 08:06 PM   #5
I removed the balance shafts from my 90 2.5 TII motor, but I opted to have the rotating assy balanced instead (i.e rods, pistons, crank and flywheel). I haven't put the motor in the car yet.....I hope the extra money I spent on engine balancing was worth it.
T
turbojerk is offline
Old 02-18-2005, 08:10 PM   #6
T
I had it balanced too, but I guess the MP mounts are really hard,
Old 02-18-2005, 08:15 PM   #7
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
I removed them from two of my 2.5L engines. I didn't notice any difference with them removed. Both as far as power and vibrations.
Una is offline
Old 02-18-2005, 08:38 PM   #8
I don't care much for any of the [[[[[HARDER]]]]] motor mounts. I lived with them for a while in my GLH-T, but I finally got the shitz of them and changed back to factory mounts. Nice, quite, smooth, relaxing factory mounts. I don't think that I'll ever go back to hardened mounts now that I know first hand what the differences are. Unless its strictly a race car....
T
Old 02-18-2005, 09:04 PM   #9
I am going to try Poly Bushings mounts, they are softer but harder if that makes sense. Still leaving the shafts in though,
Old 02-18-2005, 10:13 PM   #10
Una
Engine: 2.5L Turbo
I have a polybushings tranny mount, no vibration increase when it was installed.
Una is offline
Old 02-19-2005, 09:55 AM   #11
Lt.Lee
gary donovan says to yank those shafts frees up 10-15 hp. It also gives the advatage of another quart of oil.
Old 02-19-2005, 10:36 AM   #12
My Ride: 89TII Shelby Daytona
Images: 6
Chrysler copied the balance shaft idea from the similar sized engines in the Porsche 944...the engineers put those things in there for a reason boys and girls! Mine runs soooooo smooth with them, and the idea of that car cruising at 140+mph over here without them would be ludicrous...other (safer/saner) ways to free up HP, and more than that, maintain drivability and reliablity...
desertsnake1991 is offline
Old 02-19-2005, 02:19 PM   #13
Una
Engine: 2.5L Turbo
Advantage? My oil cost $5 a quart. I left the balance shafts in the pan, simply cut the chain. Last time I did it I cut the chain, removed them, plugged the oil hole and put on the CB 2.2 oil pan.
Una is offline
Old 02-19-2005, 03:03 PM   #14
My Ride: Dodge Spirit R/T
Engine: 2.2L Turbo III
I've removed them entirely from two 2.5 T1 engines. I'm not sure if the car was really any faster but they would sure rev faster. Defintately made heel-and-toe shifting a little snappier.
iTurbo is offline
Old 02-19-2005, 03:07 PM   #15
The only time that will help is up the rev range, which makes total sense, as rotating mass is energy etc but for a daily driver, I doubt you will notice too much. I didnt notice any difference in how fast it revs but I also have an automatic. As for the 10-15Hp, that has been debated and no one has any real dyno proof, I think on Donovans site, he figures it worth a few HP. If you do remove them, you need to baffle the oil pan or you will get big time slosh which will negate the benefits or use a shallower oil pan,
Inkjet Printer | Free Advertising | Edinburgh Hotel | Credit Card Shop | Car Accident Attorney Los Angeles
Page generated in 0.43435 seconds with 13 queries
