Old 03-03-2005, 05:29 AM   #16
Originally Posted by more_power
Balancing is just not for hi revin motors it really helps with the over all life of the motor in any aplication
But in reality its not that easy.I was rebuilding one crysler 2.2 bottom a year ago.Difference in piston weights was over 3 grams! Where to take that much material off? And worst case was, all were more or less close, and one was lighter than all other in more than 3 grams.Clean, not worn, stock turbo mahles! Have done them in 1 gram.Guys from local shop claim they should be done to 0.02gram! Similar story is with rods, crank, flywheel. Flywheel they balance here only up to 6000. For us its ok, but for suzuki its a half of rpm.
ebola is offline
Old 03-05-2005, 01:22 AM   #17
My Ride: 2004 SRT4
Engine: 2.4
Feedback: (-1)
The more balanced it is, the higher it can rev to a point. Most import motors have bearing surfaces alot smaller than we do. They have alot less drag, plus they have a shorted bore/stroke ratio where as we have a long stroke and butt loads of torque. Darrell Cox runs his SRT4 up to 10,000 rpm, so I am sure with the proper balancing, our motors should be able to hit 8,000-10,000 too. Your gonna want some light weight parts in there.
Andre Parker is offline
Books | Debt Help | Mobile Phones | Child Trust Funds | Gas Suppliers
Page generated in 0.32008 seconds with 13 queries
