Old 02-21-2005, 07:23 PM   #1
Anyone running 8.5 compression with 2.2L
Hey guys I'm ordering everything to build my motor, and I want to go with higher compression to rev up faster. I was wondering if anyone anyone is running 8.5:1 I know all about detonation, so you dont have to warn me
Thanks, Matt
glhs#064 is offline
Old 02-21-2005, 07:54 PM   #2
If you get a custom cal, run a good intercooler, and higher octane gas, won't be an issue. Then again, the stock 2.2L ratio is around 8.2 so .3 wont' make much difference.
Old 02-21-2005, 08:00 PM   #3
Yea, Thats what I planned on doing, I just wasnt sure why nobody that sells them gives the option to change the compression.
glhs#064 is offline
Old 02-21-2005, 09:16 PM   #4
My Ride: 1985 Dodge Omni GLH
Engine: 2.2l
I stuck with stock compression, but plan on using calibration tricks to get the car to spool. (at low rpm and high load, retard ignition timing a few degrees and add some extra fuel to kick the turbine)
TheRock is offline
Old 02-21-2005, 09:30 PM   #5
OOh fireworks with the extra fuel for spool,
Old 02-21-2005, 10:03 PM   #6
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
The pistons? It's hard enough to get an order of pistons that work at all in our cars from the major manufactors (Wiseco, JE, etc..). The vendors that do carry those forged pistons are already having to order up large batches of custom pistons for our cars. It just wouldn't be practical to have them any more customized than that. Now you could easily contact the manufacturer of your choice, and have them make you the custom piston of your dreams, and it's not a whole lot more than the vendors charge, as I understand..
Una is offline
Old 02-21-2005, 10:11 PM   #7
My Ride: 1986 Shelby Charger
Engine: 2.2 pseudo TII
Doesn't a 2.2 with G-head pistons and a 782 head have compression around 8.5? Maybe even a couple of tenths more?
The S is Silent is offline
Old 02-21-2005, 10:46 PM   #8
Well I have a FM Enforcer II Head, so I guess I'll have to contact the manufacturer and have a set made. Thanks for the info guys.
glhs#064 is offline
Old 02-22-2005, 12:45 AM   #9
My Ride: 84 Chrysler Laser
Engine: 92 com. blk. 2.2
My 2.2 CR is 8.58 to1, Just be sure to tune it properly.
2.2=8 is offline
Old 02-22-2005, 07:18 AM   #10
Turbo's Unleashed is doin my cal. So I should be ok.
Matt
glhs#064 is offline
Old 02-22-2005, 07:24 AM   #11
My Ride: 1987 Shelby GLHS 189
Off boost the car will like it.
glhsken is offline
Old 02-22-2005, 09:07 PM   #12
Hybrid Booster
My Ride: '86 Omni GLHS
Engine: 2.2 Turbo
Hmm . . My TD ignorance is emerging . . . Are there different pistons for g-head motors vs swirl head motors?
Can someone please explain this for me?
Eric Shelton
'86 GLHS #422 - 13.232@106.046
2.2 TII O-ringed Common Block w/ forged JE pistons, G Head w/ studs, Adj. Cam Sprocket, RP 3 bar cal (+40's), Ported Exhaust Manifold, Turbo: 50 trim-tO4E comp. wheel/ .63 exh housing, 3" s.v./downpipe, A555, 22x8x15 ET Drags
My Website
GLHS422 is offline
Old 02-22-2005, 09:12 PM   #13
It's common for people to put a g-head on an engine with swirl head pistons to lower the compression.
The opposite is true for raising compression. 782 head on an engine with g-head pistons.
The g-heads have a slightly larger combustion chamber than the 782 head. In order to keep the compression the same when they moved to the 782 head, they used pistons with a slightly deeper dish.
Just in case nobody has passed this your way (and I can't imagine this being the case ) www.thedodgegarage.com
Old 02-22-2005, 09:23 PM   #14
Una
Engine: 2.5L Turbo
Yeah, I do that on every N/A engine I get near. Swirl head and MPFI does wonders for waking up the good old HO engines.. hahah..
Una is offline
Old 02-22-2005, 09:23 PM   #15
Hybrid Booster
Engine: 2.2 Turbo
Thanks - I knew about this, but I thought all 2.2 pistons were the same and that it was merely the difference in cyl. head combustion chamber volume that was changing the compression. I just figured that swirl-head motors have a certain compression and g-head motors have a different compression. But it sounds like the pistons were also different . . .
Does JE make two different kinds of forged pistons for the 2.2 motor?
Well, that pretty much answers my other question! So all 2.2 motors came from the factory with the same compression ratio, huh?!? I guess I need to freshen up my TD-trivia knowledge!
LOL . . . Gary who??? . . .
Thanks for the clarification!
Eric Shelton
My Website
GLHS422 is offline
Mobile Phones | Loans | Gas Suppliers | MPAA | Bad Credit Mortgages
Page generated in 0.46785 seconds with 13 queries
