Old 02-23-2005, 11:36 AM   #1
Weiseco's or JE's????
I'm just making sure I order the right stuff. Which hold up better? I'll be running .040 w/ 8.5:1 comp. on a 2.2L
Matt
glhs#064 is offline
Old 02-23-2005, 12:51 PM   #2
both are equally excellent pistons. I have used JE, Wiseco, Ross and several other top quality racing pistons. all performed flawlessly. I prefer Wiseco just because of cost....they were the lowest price
22dodge is offline
Old 02-23-2005, 01:07 PM   #3
That what I was going to order, but I just wanted to make sure nobody was having issues with them.
I know that with the DSM community they are the worst. They did tests and found that the Weiseco's had a high silicon content and that was causng them to overheat and crack.
glhs#064 is offline
Old 02-23-2005, 01:13 PM   #4
My Ride: 88 Shadow
Feedback: (7)
Not the case with our engines. Wiseco's are the best bang for the buck.
moparzrule is offline
Old 02-23-2005, 01:18 PM   #5
My Ride: 1987 Shelby GLHS 189
I've seen Wiseco 2.5's (the 1st ones they made) take 460 ft lbs... on pump gas and survive head lifting detonation...
edited to add... he forgot he was running "all" of it
glhsken is offline
Old 02-23-2005, 01:22 PM   #6
My Ride: 88 Shadow
Feedback: (7)
Old 02-23-2005, 03:59 PM   #7
Authorized TD Vendor
mopar2ya's Avatar
My Ride: 91 Spirit R/T
Engine: 2.2 TIII
Id take a broken set of Wisecos over a new set of JEs, but that just me. I use the Venolias, and really like them, but if your down to the other two, go Wiseco.
Wallace
91 Spirit R/T
11.686@120.89 mph
mopar2ya is offline
Old 02-23-2005, 04:21 PM   #8
My Ride: 87 Daytona Pacifica
Engine: 2.2 Turbo I
Good stuff. I'm in this debate right now. The owner of the Enforcer II block I'm buying suggests the JE's. The biggest problem is that the pins on the JE's from FM are .912". The Wiseco and Venolia's don't come in that size. Anyone know what it runs (if it's even a good idea) to open up the small end to .927? The JE's are $100 more a set from FM, but if it's gonna cost $75 to punch the rods, I'd rather save my time and spend a little more.
god910 is offline
Old 02-23-2005, 04:37 PM   #9
My Ride: 88 Shadow
Feedback: (7)
Wiseco's can come in stock .901 size or the .927.
It will be atleast 75 to bore the small end on the rods, so YOUR best bet is to go JE's since you already have the .912 pin.
Old 02-23-2005, 06:13 PM   #10
My Ride: 92 Daytona Iroc R/T
Engine: 2.4 T-III
I like Je pistons! They are probably the lightest piston you can get for our motors, yea they are a little more expensive but their the best.
Chuck
Chucksrt is offline
Old 02-23-2005, 10:08 PM   #11
my thoughts
My Ride: 85 Charger
Like you, I had the same question. The mechanic that saved my hyde on my turbo dodge uses JE. He has a Charger running 18-20psi daily. (18 on CAL then bled to squeeze 2) That man can't keep tires on that thing! He has had no complaints after a year like that.
john1320 is offline
Old 02-23-2005, 10:13 PM   #12
My Ride: 88 Shadow
Feedback: (7)
I run 22 PSI daily on stock cast Mahles, its all in the tune
Old 02-23-2005, 10:16 PM   #13
all in the tune
My Ride: 85 Charger
HAHA, the JEs got MAHLED!
john1320 is offline
Old 02-23-2005, 10:21 PM   #14
My Ride: CSXT
The venolias that TU sells comes with Total Seal rings.... or they are called some thing like that.... they are supposed to seal super awesome.... so that you motor has less then 5% leakdown or something like that
juxsa is offline
Old 02-23-2005, 10:23 PM   #15
Engine: 2.4 T-III
How much do the Mahle pistons weigh? My JE pistons weigh 108 grams less (each) than stock. I consider Mahle a good piston but I see JE as an upgrade
Chucksrt is offline
Buy Shares | Xecuter 3 Mod Chip | The eBay Song | Shares | Mortgages
Page generated in 0.48080 seconds with 13 queries
