02-27-2005, 12:12 PM
My Ride: 87 Daytona Pacifica
Engine: 2.2 Turbo I
Build it back to standard size? Can't say I've ever heard of that, can't say that if it was possible it'd be very easy. I'd just turn, polish, and go oversized bearings.
02-27-2005, 01:35 PM
Engine: 2.2 Turbo I
Originally Posted by GLHS0658
Yes you can build it up back to standard. Although it is not cost effective or wise. When you do have it ground for .010 bearings, ask the machine shop what they will charge to build it back up to standard...very expensive!
Seems a little rediculous unless you had a custom forged crank and took a big chunk out of it.
02-27-2005, 03:35 PM
My Ride: '88 Shelby Z TII
Or you stroked a 2.2 crank to 3.75"
02-27-2005, 07:54 PM
My Ride: 88 Lancer Shelby
Engine: 4cyl. 2.5L
Or you de-stroked a 2.2 to a 2.0
02-27-2005, 09:15 PM
Engine: 2.2 Turbo I
But it would still be cheaper to get another and turn it to where you want.
02-27-2005, 11:29 PM
My Ride: '89 Daytona Shelby
They weld them up. I'd only consider it for one journal though. Anymore than that just isn't worth the trouble/money.
03-04-2005, 02:47 AM
My Ride: Omni
LOL +1 3.0Duster
i would suggest going oversize bearings as stated, more cost effective
03-04-2005, 04:48 PM
My Ride: Mini, Shadow, LeBaro
Engine: 2.5 T1 & 2.2 T4
I wouldn't built up the crank by welding, its only a short term solution. Welding weakens it. If you only intend to run it for a year or so, might be OK. The fatique resistance to progressive cracking is reduced to a fraction of it's original design. Going to oversize bearings is a much safer route.
That is, a tiny crack will start at the weld and and gets bigger and bigger till it breaks the crank, a lot earlier than originally designed!
03-04-2005, 06:10 PM
#12
My Ride: 1987 Shelby GLHS 189
Nothing wrong with a .010 crank... I just had 3 done!! one is for a 400whp engine.
03-04-2005, 08:26 PM
#13
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
I've never heard of a good weld causing any problems with the crank. And no, it's not a temporary solution. The new metal is bonded to the existing metal, and then the weld is ground to match the size of the other journals. The hole is then chamfered and the journals polished. I don't know where you got your information, but it's incorrect. I worked in a crank shop for a while and there were never any returns due to bad welds, or welds causing problems.
03-05-2005, 01:15 AM
#14
My Ride: 2004 SRT4
Engine: 2.4
It would depend on what type of material was used when it was welded. I am not sure for the auto world, but in the plastic mold injection arena, they have a chrome plating they use for friction that builds up the surface of the screws used for injecting hot plastic. This stuff is cheaper than having it welded and is designed to reduce wear. Cheapest would be have it turned down. They can only turn it so far due to heat treating. some of them are nitrided and may only penetrate the metal .020-.100 or so depending on the parent metal.
