Old 02-27-2005, 09:16 PM   #1
n/a 2.5 with g head compression
cky
My Ride: 90 daytona shelby
Engine: 2.5 intercooled
i really don't like the 7.8 comp ratio of the turbos so i was thinking of ways to get it to like 8.5 or so. what would the comp be on a tbi 2.5 if you put on a g head or a g head with bowl work or a swirl with lots of bowl work. i know this gets discussed alot but i feel strongly on slightly higher compression and everyone usually rags on it. but with the right tuning and mild boost like up to 18 lbs max it would definetly be benificial for a street car.
cky is offline
Old 02-27-2005, 11:31 PM   #2
Una
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
What's the compression ratio of an N/A 2.5? The G head usually drops compression ratio's by .5 and makes the engine far more knock resistant. I'd bet it'd work great for ya. Stick to 2.5 electronics..
Una is offline
Old 02-28-2005, 09:28 PM   #3
cky
an n/a 2.5's comp ratio is 8.9:1. if it drops it .5 that would be soooo sweet. right where i want it. man anyone else have any input.
cky is offline
Old 02-28-2005, 09:29 PM   #4
cky
wait don't all g heads have 10mm head bolts. so i would need the holes bored out to 11. anything else im missing.
cky is offline
Old 02-28-2005, 09:53 PM   #5
My Ride: 94 Dodge Caravan
Engine: 3.0L V6
I just put a G head on my 89 2.5L CB for my shadow. I didn't notice any problems with the larger bolts.
mwinkle353 is offline
Old 03-01-2005, 12:32 AM   #6
Una
Engine: 2.5L Turbo
I had a minor amount of trouble getting 11mm headbolts into my G head.. But they all fit in, just a couple were very snug.
Una is offline
Old 03-01-2005, 02:17 AM   #7
My Ride: 1987 CSX
Images: 4
they will fit like una said some will be tight the ones that where tight for me was the inner bolts
RSTURBO is offline
Old 03-01-2005, 01:42 PM   #8
My Ride: 87 GLHS
Some G heads fit 11mm head bolts and some don't. On mine some bolts would fit and some wouldn't. I fixed this by running a 7/16 (pretty sure it was 7/16) drill bit down each hole to take just a little material off and make it fit. It really didn't take much and can be done with the average cheapo drill.
-Rich
rfb6435 is offline
Old 03-01-2005, 02:23 PM   #9
My Ride: 88 Shadow
Feedback: (7)
I think it's the 287 G head castings that fit the 11mm bolts (thats what mine is and I don't think it was drilled out) easily but the 445 casting G head doesn't or are very tight.
moparzrule is offline
Old 03-01-2005, 10:31 PM   #10
cky
so what does anyone think of the higher compression setup.
cky is offline
Old 03-01-2005, 10:44 PM   #11
My Ride: 88 Shadow
Feedback: (7)
Not worth it, the little you gain on the low end is not worth sacrificing not being about to run more boost. I went with a G head so I could safely run 22 PSI on pump gas VS sticking with a swirl and being stuck with 18ish. Thats about 30 HP difference minus maybe 5 for the lower compression but a G head also flows more air so even more HP up top, I figure about 40 HP gain overall.
Bad Credit Mortgages | Loans | Personal Finance | Bad Credit Mortgages | Project cars
Page generated in 0.36677 seconds with 13 queries
