Old 03-30-2005, 07:45 PM   #16
My Ride: 05 SRT4
Engine: 2.4L
Originally Posted by wrenchbreaker
I am tearing down my shortblock and I found small pieces of what looked to be brass. I looked around and didn't find any missing bushings...WTF? Kind of concerned, but glad I caught it when I did. Pulled out all the pistons and checked my rod bearing clearences and all were good....bearings looked really good. I will pull the crank out Thursday and hopefully find out where these peices came from. I also have some wear on the cylinder walls from the piston skirts...is this normal? Nothing big....I could easily get rid of it with a cylinder hone and about 30 seconeds.
I dont see how the Turbo's center section could completely disintegrate a bearing. Ive extreme wear on the bearing but never see one blow. Also, if the bearing did blow apart, It would have had to completely go inorder for it to get it through the Oil Drain.
Lets say it is the turbo.. Check for excessive shaft-play or binding. IMHO if the Bearing turned it confetti the oil seal would have bit the dust.
As with an engine you will need to perform a complete tear-down and inspection. In almost all cases you will find the root of the problem.
Here is a list of Items in the engine that would be of a Goldish/Brass color
-Main and Rod Bearings
-Freeze Plugs
-Valve Guides
-Some Alignment dowels
-Turbo Bearings
Robert S.
87 GLHS Charger #918
Dominion is offline
eHarmony Promotional Code | Loans | Problem Mortgage | Credit Cards | Credit Cards
Page generated in 0.27711 seconds with 13 queries
