Old 03-21-2005, 11:27 PM   #1
Found stuff in block
My Ride: '87 GLHS #369
Engine: 2.2 sohc
Images: 3
I am tearing down my shortblock and I found small pieces of what looked to be brass. I looked around and didn't find any missing bushings...WTF? Kind of concerned, but glad I caught it when I did. Pulled out all the pistons and checked my rod bearing clearences and all were good....bearings looked really good. I will pull the crank out Thursday and hopefully find out where these peices came from. I also have some wear on the cylinder walls from the piston skirts...is this normal? Nothing big....I could easily get rid of it with a cylinder hone and about 30 seconeds.
wrenchbreaker is offline
Old 03-22-2005, 12:08 AM   #2
My Ride: '89 Daytona Shelby
Turbo shaft bearings?
puppet is offline
Old 03-22-2005, 01:01 AM   #3
My Ride: 87 GLHS
Engine: 2.2 16V Maserati
Could be main bearing material if your crank is still in. You'll know when you pull it.
Alan
2.216vturbo is offline
Old 03-22-2005, 04:58 AM   #4
My Ride: '87 Lebaron Coupe
Engine: mild 2.2 TII
Where did you find the pieces? Are they pieces of piston rings?
Moparmonster is offline
Old 03-22-2005, 08:40 AM   #5
+1
im pretty sure the turbo bearings are brass.
mo' parts is offline
Old 03-22-2005, 09:45 AM   #6
My Ride: 86 GLH-T 2.5 W/A568
Engine: 2.5 T3T4 hybrid
If mains are OK, then +2. Turbo bearings are brass, at least all I have seen
TheGinMill is offline
Old 03-22-2005, 09:48 AM   #7
My Ride: 1987 Shelby GLHS 189
Check the int shaft bushing
glhsken is offline
Old 03-22-2005, 09:51 AM   #8
My Ride: 87 Shelby Charger
Engine: 2.2l 135CI
It is most likely a bearing somewhere. The factory bearings are Tri-metal, and once they are worn past a point, you can see the brass.
I've seen it before, and if you haven't seen it on the rods, then its on the mains - or like Ken said, the intermediate shaft.
mw6886 is offline
Old 03-22-2005, 10:43 AM   #9
My Ride: 85 Daytona Turbo Z
Engine: 2.2 L Turbo II
Any Pics?
Leafy is offline
Old 03-22-2005, 05:02 PM   #10
My Ride: 82 Dodge Rampage
Engine: Turbo I 2.2L
When i pulled my old original Garrett Turbo apart it had Aluminium bearings, not brass. I think only good aftermarket rebuilt turbos come with brass bearings like a TU turbo.
Turbo_Rampage is offline
Old 03-22-2005, 05:40 PM   #11
If your pan look something like....
And the bearing looked like....
Then your crank will look like....
sorry for the pic size
Torka is offline
Old 03-22-2005, 05:43 PM   #12
I love visual references!
Leafy is offline
Old 03-22-2005, 05:45 PM   #13
My Ride: 1986 Shelby Charger
Engine: 2.2 pseudo TII
Don't be. I like large pictues...especially if they show detail like crank damage. Carnage is always more fun when you don't have to wonder what you are looking at
The S is Silent is offline
Old 03-22-2005, 06:57 PM   #14
Engine: 2.2 sohc
Images: 3
My pan didn't look like that at all. It was only 4 or so peices. Bearings and crank look new....almost no wear. Block has less than 30k on it. I am pulling it apart for the mighty 16 valve hybrid conversion. I want to post pics, but I don't know how to do it. I have them saved on my computer, I just need to post them on here. Anyone want to steer me in the right direction?
Old 03-22-2005, 07:32 PM   #15
My Ride: 1984 Daytona
Engine: 2.2L Turbo 1
you have to be a contributing member to attach pics on this site. If you have them hosted somewhere else you can link to them though.
when posting hit the little icon that hasa the world and the chain link. Then type in the url of where your pic is and it should work. good luck
SwiftTech is offline
Credit Cards | Mobile Phone | Loans | Loans | Mortgage Calculator
Page generated in 0.66059 seconds with 13 queries
