Old 04-01-2005, 01:13 AM   #1
90 n/a block
My Ride: Daytona
Engine: 2.2 liters
is it possible to take a 90 n/a block and build it up for a turbo application.
just here say.......not cheapest way
i have a 90 n/a block just laying around. The thought of using it to build a superior engine over my 88 block crossed my mind. I could use it in a turbo application assuming i totally replace every part, right? or are they weaker than a turbo block. isn't it just a common block?
Realest is offline
Old 04-01-2005, 02:50 AM   #2
That's pretty much what I'm doing. I found a 91 2.2 NA motor. Get some HD rods from a T2 or 2.5 T1 engine, and you'll need turbo pistons as well. Beyond that, you'll have to drill a hole for the oil return for the turbo, but there's not much else to it.
supercrackerbox is offline
Old 04-01-2005, 05:56 AM   #3
What he said and you might have to drill the cross drill holes in the deck, some had them, some didn't.
Old 04-04-2005, 03:43 AM   #4
okay
My Ride: Daytona
Engine: 2.2 liters
i am aware of the differences in pistons and rods, but can you clarify cranks.
I know CB cranks are not interchangable with earlier blocks, and I know that 2.2 and 2.5 cranks are different. What i need clarifying is, are the cast TBI cranks the same or different from a cast turbo cranks?
Realest is offline
Old 04-04-2005, 12:01 PM   #5
cawcislo's Avatar
My Ride: 87 Shelby daytona T2
Engine: 2.5 bored 0.20
Feedback: (6)
Images: 4
I don't believe there is any difference between cast turbo and non turbo common block cranks. I've also converted a non turbo common block into a common block that is in the car right now.
cawcislo is offline
Old 04-04-2005, 07:47 PM   #6
To my knowledge, as far as Common Blocks go, there are three different cranks. 2.5, turbo'd or not, are cast. 2.2 TBI are also cast. And 2.2 Turbo (TII, TIII, TIV, and Masi headed) were all forged. There are some discrepancies concerning the 89 CSX-VNT and the Maserati TC, but that's the gist of it.
HUH?
Old 04-04-2005, 07:52 PM   #7
HUH?
What he's saying is turbo to tbi, crank is the same-CB. He made a tbi CB into a turbo CB engine,
Old 04-05-2005, 01:10 AM   #8
Ok, I'm a moron. Somehow I misread it and didn't realize he did the exact same thing I'm doing.
Old 04-05-2005, 01:15 AM   #9
i didn't know there was a difference between turbo rods and non turbo rods in a common block motor. or was supercrackerbox saying that those rods he mentioned are better anyway?
tony
macncheese is offline
Old 04-05-2005, 12:14 PM   #10
The turbo CB motors got the heavy duty rods, and the non-turbo CB motors got some really wimpy ones. You can tell a huge difference when they're side by side. Personally, the rods I'm using are from an 87 TII engine.
Old 04-05-2005, 12:17 PM   #11
Which BTW, are the same as CB turbo rods,
Xbox Mod Chip | Web Advertising | MPAA | Credit Cards | Cheap Loan
Page generated in 0.45633 seconds with 13 queries
