04-09-2005, 09:54 AM
Originally Posted by supercrackerbox
Where exactly is this piece?
It's in an oil gallery in the block. Looking from the front of the car, it's on the right hand side, front, closest to you. Removing it would not be concidered a mod IMO. Lower oil pressure will be a result and at very high rpms with high boost for extended periods, an over accumulation of oil in the valve cover area and eventual spraying out the pcv may happen.
