04-12-2005, 09:37 PM
Originally Posted by 89acclaim
Does anyone have any experience with our engines and running a tight piston to head clearance (squash) of around .035", either NA or turbo? Thanks for your time.
Daniel Merrill
Thats actually "quench area"
Sorry, couldn't resist,
04-12-2005, 10:59 PM
My Ride: Horizon GLH-T
Engine: 2.5L Turbo
What octane do you have to run at 14.5:1?
04-13-2005, 06:42 AM
My Ride: 1987 Shelby GLHS 189
22dodge. What's the benefit of the quench?? Should off boost response be helped??
04-13-2005, 07:22 AM
My Ride: 1991 Daytona Shelby
Engine: 2.5L
read this ken,
http://www.theoldone.com/archive/quench-area.htm
04-13-2005, 07:27 AM
Engine: 2.5L
as you can tell, he promotes higher compression turbo motors... of course he is working with none pita heads, but the point is still made.
04-13-2005, 07:36 AM
Engine: 2.5L
Here is a good example...
04-14-2005, 09:14 AM
Originally Posted by Frank
Good read. Thanks. due to our dish for the turbo's, it's kinda outta the question
04-14-2005, 09:48 AM
#12
Engine: 2.5L
Unless you redesign the piston top. However that would up the compression to around 10.5:1. With the thermal issue with hot air flow from bad flow and being non cross fed, you will be both hotter, and have more issues with keeping hot spots out of the combustion chamber. knock, knock, boom!!!!!
frank
04-14-2005, 12:27 PM
#13
frank
Yes, hello,
04-14-2005, 01:13 PM
#14
Engine: 2.5L
Originally Posted by turbovanman
Yes, hello,
Can I pardon you for some metal slag?
04-14-2005, 01:14 PM
#15
Hahaha, think I have some for you, sounds like I cracked another piston, doh!
