Old 04-15-2005, 01:24 PM   #1
Oil Pump
Unusual car guy
quantum's Avatar
My Ride: 89 CSX #91
I figured as long as I have the botton end of my engine appart I might as weel replace the oil pump, after all it's been running 140,000 miles. So I call the dealer and get a quote of $140! Then later while at autozone I'm talking to the guy and he has a Melling for $50. Is there so much of a difference between the two that the stock is $90 dollars better? Basically which should I get?
quantum is offline
Old 04-15-2005, 09:58 PM   #2
Feedback: (7)
I would not hesitate to buy a decent name aftermarket pump. Some things are better to use the dealer but not in this case (in my opinion anyway).
gakali is offline
Old 04-16-2005, 02:35 AM   #3
Oil Pump
A Melling Oil Pump is fine if not great to use.
Mike
GLHS0658 is offline
Old 04-16-2005, 07:33 PM   #4
Unusual car guy
quantum's Avatar
My Ride: 89 CSX #91
Thanks guys
quantum is offline
Old 04-16-2005, 08:12 PM   #5
Theres only a few pump manufacterers so a dealer pump is probably a melling or ? so buy away.
While you have the new pump on the counter, install Mopars spring kit, #P3690944
Gives you a bit more pressure, works awesome!
Old 05-01-2005, 05:53 PM   #6
My Ride: 2.4 Turbo Spirit
Engine: 2.4 DOHC
what is the spring kit for? any oil pump? I was wondering
I have a new oil pump I got from a guy cleaning out her junk and I don't know how to identify the manufacturer, because on thedodgegaradge it says that one pump eats 7hp?
thanks sorry for the hijack
speeduphoria is offline
Old 05-01-2005, 07:55 PM   #7
sorry to hijack the tread but how do you exactly install the relief spring?
bmxrider is offline
Old 05-01-2005, 09:39 PM   #8
My Ride: '89 Daytona Shelby
Pull the cotter pin ... thread a self taping screw into the plug behind the pin so you can pull it out.
Lift out the spring .... don't turn the pump over until you realise that there is a valve behind the spring and how it sits. You'll want to remove that to clean it incase you got some shavings from the old plug on it.
Put the valve back and insert the new spring. Tap in the new plug and replace the cotter pin.
puppet is offline
Movies download | Loans | Debt Consolidation | Loans | McDonalds
Page generated in 0.34640 seconds with 13 queries
