04-23-2005, 11:22 AM
urgent rod bearing question
My Ride: 1992 Lebaron
Engine: 3.0L
OK, my car started knocking so I decided to look at the rod bearings. I currently have bearings from cylinders 1 and 4 out and they are definately beginning to wear (bit of copper showing) However, the crank seems to be free of scratches/grooves. So I am going to put in new rod bearings this morning when I get an answer...
Question is this:
I pulled the 1 and 4 rod caps, and it seems like one is backwards. The groove that the bearing sits in was different between the two (one facing forward / one backward). Just wondering what the proper way for them to be on there is?
04-23-2005, 11:34 AM
Engine: 3.0L
I bought this car at 197000km and I don't know what the service history of it is. However, both pistons have the lock on the same side, it is the caps that do not.
So if I just put the one backwards cap on so that the two tabs are together it should be ok?
04-23-2005, 12:05 PM
Engine: 3.0L
anyone else? I want to get this back together this morning.
04-23-2005, 12:33 PM
Engine: 3.0L
just one more question... is it good enough just to coat the bearing surface with fresh oil or should I get some proper assembly lube?
04-23-2005, 12:55 PM
My Ride: '89 CSX T3/T4
Engine: 153ci
i have used just oil once when i put new bearings in my car. nothing went wrong, that was like 10k miles ago
04-23-2005, 04:04 PM
Engine: 3.0L
I just got my rod bearings on and all the caps went back on the same rod they came off and also the tabs are on the same side so all should be well. Just need to get the oil pan on.
04-24-2005, 02:10 PM
update??
i may be doing the same thing. mine has a very faint knock that just started.
it was a back up motor that i put in, only to find a busted #1, replaced that..all was good... then oil pump died, drove it maybe 1/8 mile before i noticed no press, changed the pump.. 100 miles later i hear the knock
i just cant win.... i have a set of new bearings here, for my motor thats at the shop...thinking i may just toss them in.
hope all turns out good for you. did you plastigauge them??
